Asbestos Mastic - Flooring - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 12:45 AM   #1
asbestos mastic
I am renovating an apartment and have removed vinyl tiles from concrete floor. A good amount of mastic remains. I started trying to remove it using an eco-friendly solvent. However, even with considerable patience and effort, mastic remains. I have seen it alluded to in several threads that you can place a skim coat over the mastic that would both stabilize any possible asbestos and prepare the floor. I would like to use several flooring techniques. Tile in the bathroom. Laminate flooring in the living area. A stainable concrete in the kitchen. I have several questions. What products would produce a stable surface? Can I treat the kitchen area so that skim coat will be solid and the mastic will not bleed through. I am familiar with the precautions that must be taken because of the possible presence of asbestos in the mastic. Thanks for any info.
josec is offline   Reply With Quote
Old 01-03-2012, 07:24 AM   #2
Retired Moderator
Rewards Points: 7,174
The black mastic is called 'cut back'---the asbestos is a minor concern as powdered-airborne asbestos fibers are the only think that can cause heath issues----and there is no likely hood of that sticky goo getting air borne.
Ceramic is easy---some modified thinsets will work right out of the bag---or use an unmodified with a liquid additive---check with the manufacturer--
Call the maker of the laminate for a recommendation---or wait for another member to answer.
You will never get the concrete clean enough to stain---that cutback has soaked in to deep to ever stain.
You 'eco friendly' solvent was a bad idea---that may have dissolved the cutback and driven it deep into the concrete and left behind solvent that will be a 'bond breaker' causing problems for the thinset--Mike--
ben's plumbing (01-03-2012)
Old 01-03-2012, 12:58 PM   #3
I have only applied the solvent in the bathroom area and the kitchen area. Still have the living area left to do. Not sure what you mean by ceramic is easy. Thanks for the info.
Old 01-03-2012, 08:15 PM   #4
Retired Moderator
Ceramic tile can be installed right over cut back with nothing more than scraping off the goo with a razor scraper --then a two part thinset or a modified thinset approved for use over cut back--
The solvent could cause you problems,however---they are known to be bond breakers--better wash the area well--
Old 01-04-2012, 12:03 PM   #5
Thanks for the clarification. I appreciate the advice.
Asbestos tile and mastic phillyDIYER Flooring 14 08-21-2011 02:46 PM
New Project Started, Fear Growing -- Wall Tiles and Asbestos Mastic? itcanadian Remodeling 5 03-19-2011 01:11 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-17-2010 12:28 AM
Asbestos Black Mastic Removal? Ken-SanDiego General DIY Discussions 3 12-30-2009 09:26 AM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
