Around Cabinets And Sills - Flooring - DIY Chatroom Home Improvement Forum
Old 05-29-2017, 03:40 PM   #1
Rewards Points: 115
Around cabinets and sills
Hello all
I am planning to do my second floor with laminate. There is a 10x12ft landing area that is surrounded by sills on both sides and cabinets on one side.
Visually, I think I should butt the laminate against the sills and cabinets without leaving a gap. However wouldn't this a problem for expansion an contraction of the flooring?
How do pros usually approach these items?
Thanks much
jemhunter is offline   Reply With Quote
Old 05-29-2017, 04:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,650
Re: Around cabinets and sills
1/4 round molding stained to match the floor.
Many floors will have it as an option pre-stained/finished.
Old 05-29-2017, 05:41 PM   #3
Rewards Points: 898
I'd probably use a T moulding For the shoe rail in your situation.
BIG Johnson is offline   Reply With Quote
Old 05-29-2017, 07:01 PM   #4
Professional
Rewards Points: 188
You can use a t moulding at the rail or just make a thin rip to put over the edge. On the cabinet side you install a lick plate after the flooring goes in.
Str8AheadInc is offline   Reply With Quote
Old 05-31-2017, 07:49 PM   #5
Rewards Points: 115
Is it for the cabinet to the floor transition? I was planning on doing that where the baseboard is and match the trim color.
Sent from my iPad using Tapatalk
Old 05-31-2017, 07:54 PM   #6
Rewards Points: 115
What is a lick plate?
The T moulding look visually odd to me. I forgot to mention, I have 2 sill plate. One is curved.
Old 05-31-2017, 08:16 PM   #7
Mike Milam's Avatar
Rewards Points: 176
Your cabinet doesn't appear to have a toe kick recess. If that is the case, use color matched 1/4 round and attach it to the cabinet rather than the floor. That will allow the flooring to expand and contract.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 05-31-2017, 10:58 PM   #8
That was a typo for Str8. He was saying "kickplate" but the K and L are next to each other.
