Applying Thinset On Floor/Wall Surface Or On Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 12-12-2014, 03:27 PM   #1
Rewards Points: 278
Applying Thinset on Floor/Wall Surface or on Tiles
All,
I learned that there are 2 options applying thinset for floor/wall tiling with trowel:
1. apply the thinset directly on the floor/wall and place the tiles
2. apply the thinset on the back of tiles and place the tiles
The second option seems cleaner, but I want to check with you all if one is better than the others.
Thanks!
325_man is offline   Reply With Quote
Old 12-12-2014, 04:50 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by 325_man View Post
All,
Thanks!
#2 is very wrong!... Unless you need to back butter the tiles thinset still is required on the surface.
It requires one to know how to apply the thinset the wall/floor correctly, with the write consistently applying thinset 1st flat then use the notch side of trowel to make ur lines.
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
JazMan (12-12-2014)
Old 12-12-2014, 06:36 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 780
You've got it backwards.
However, you may need/want to also 'butter' the backs of the tiles too.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
JetSwet (12-12-2014)
Old 12-12-2014, 09:00 PM   #4
Rewards Points: 1,684
Cleaner isn't either correct....or speedy. Thinset goes on the surface first, gets used in hard with the flat side of the trowel, then gets combed out with the grooved side. Tile is set nicely into that. It is POSSIBLE that you might also have to back butter some tiles...but that is not common for most standard tiles. Mexican terra cotta or the like yes. Ron
ront02769 is online now   Reply With Quote
Old 12-12-2014, 11:56 PM   #5
Rewards Points: 278
Thank you, everyone!
applying glass wall tiles directly on an unfinished 2x4 beech Kitchen & Bath Remodeling 7 09-07-2011 07:40 PM
Laying Tiles Over Partially Removed Thinset LinusHarmon Flooring 2 08-31-2011 10:29 AM
how to remove hardened thinset from tiles amakarevic Flooring 16 07-11-2011 07:44 PM
How to remove thinset residue after old tiles removed? sz8 Flooring 11 01-01-2011 10:49 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
