Any Reason To Not Throw Away Extra Used Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2018, 01:28 PM   #1
Jeff Walker's Avatar
Rewards Points: 18
Any reason to not throw away extra used flooring?
I got a batch of 2.25" wide, factory-finished, 7 year old Oak flooring in exchange for removing it from the owner's home. I have laid a floor with the usable planks, leaving me with the rejected pieces.
Most of the remaining boards can't be used for flooring without refinishing the walking surface and others lack their tongues or grooves on the long sides.
They have the factory stain and varnish on the walking surface, so they can't be burned, they have staples that need to be removed before macining them, and most are bowed. They are 2.25" wide by 1' to 6' long, by .75" thick. Is there any justification for removing the staples and finish, and reusing the boards? I usually keep everything but I can't believe that it is worth the effort in this case. Can anyone explain how it would be a tragic waste to throw it away?
Thanks.
Jeff Walker is offline   Reply With Quote
Old 11-08-2018, 01:40 PM   #2
retired framer
Rewards Points: 1,842
Re: Any reason to not throw away extra used flooring?
I think you have already done your part by re using the floor, but I would save a few pieces. The guy that needs a few pieces for a repair is never the guy that has a few pieces.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 07:24 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
