Anchoring A Basement Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2015, 09:47 AM   #1
Rewards Points: 52
anchoring a basement subfloor
I've kind of read mixed things so far....I know some don't approve of wood subfloors in basements, but if I went ahead anyways, does it need to be anchoring.
The subfloor in question is either ply or osb overtop of DMX underlayment, which will only have carpet and laminate on top.
Does each sheet of ply/osb need to be screwed to the basement floor, if so, how many anchors are required.
I'm trying to avoid putting a whole bunch of holes in the DMX underlayment.
Thanks,
Onagoth is offline   Reply With Quote
Old 01-05-2015, 01:05 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
Laminate is not warrantied in a basement. Doesn't matter what you put under it. No idea why you would want wood under carpet in a basement.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-05-2015, 01:37 PM   #3
Rewards Points: 144
You should have at least used some 2X sleepers under the ply.You don't want the ply sitting on the concrete.DMX or whatever.Your going to have to anchor the ply somehow putting holes thru the dmx making it useless with the ply sitting right on top.
Also agree with Rusty on the rest.
mako1 is offline   Reply With Quote
Old 01-05-2015, 01:37 PM   #4
Rewards Points: 52
According to the DMX installation instructions, 5/8" T&G OSB is required for carpet.
Old 01-05-2015, 01:41 PM   #5
Rewards Points: 52
DMX is similar to delta-fl...the OSB/ply wouldn't be touching the concrete.
I've read that laminates can float on top of a floating subfloor, and I know that the OSB is required for carpet...but is there any reason why the entire subfloor can't float?
Will the carpet develop any ridges or anything like that if the subfloor is floating?
Old 01-05-2015, 02:47 PM   #6
Rewards Points: 144
I don't know where you read about a "floating subfloor".I've been in the business for 40 years and never heard such a thing.OSB or Plywood does expand and contract.
Sounds like your set on it so go ahead .When the osb starts to swell up like a biscuit and the edges start to curl up come back for some more advice on how to do it right.
Old 01-05-2015, 03:07 PM   #7
Rewards Points: 52
Well...I'd like to keep the DMX there...what is the better solution? Just laminate on top of the DMX without the OSB/ply? (forget the carpet?)
Old 01-05-2015, 03:27 PM   #8
Rewards Points: 400
Laminate is not for below grade no matter how you install it.
Old 01-05-2015, 05:56 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 780
Which laminate are you planning to use? Have you done a moisture test? Which one? You forgot to say where you're located. I would think a question about moisture and below grade floor finishing would require a rough location to help us get an idea of the weather conditions. You should insert it in your profile.
What you wanna do is a high risk installation for most locations. It can work fairly well, but only if all the stars align and the conditions don't change.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Subfloor and P-trap for basement bathroom svaic00 Plumbing 9 10-11-2012 01:51 PM
Basement Subfloor Fandu Insulation 1 09-08-2012 10:34 AM
basement subfloor Alan2011 Flooring 3 07-30-2011 04:50 PM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 02:17 PM
