Alternative To Self Leveling Concrete - Flooring - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By SeniorSitizen
  • 1 Post By Nealtw
  • 1 Post By DanoMH
Old 05-16-2018, 12:31 PM   #1
Rewards Points: 8
Alternative to self leveling concrete
Hey all,
I'm currently installing LVP in a basement room with Delta-FL and a 2mm foam underlayment. Almost finished except for this pesky entry way to the room. The section is 5 inches wide to where it meets carpet; it dips about 1/2 inch over that distance.
I would like to try to avoid buying a 50lb bag of self leveling material and would like to avoid the mess of concrete all together for what amounts to about a square foot to fix. I've tried correcting with the foam underlayment product, and have gotten close to a fix, but as you can imagine I'm getting some deflection in the planks.
Any recommendations to level out this area, preferably that do not involve concrete?
TIA
DanoMH is offline   Reply With Quote
Old 05-16-2018, 01:42 PM   #2
Rewards Points: 1,466
Re: Alternative to self leveling concrete
Some cedar shakes are nearly a half inch thick end and may have about the taper you need when installed with an adhesive.
Choose wood to ceramic on this to that.
http://thistothat.com/
DanoMH likes this.
Old 05-16-2018, 01:45 PM   #3
retired framer
Rewards Points: 20,072
https://www.homedepot.com/p/Quikrete...3311/100318504
DanoMH likes this.
Old 05-17-2018, 10:18 PM   #4
Rewards Points: 8
Just an FYI update. I removed the excess foam and used some good ole 1.25"x7.75" shims so I could customize the leveling with every plank. This has gone a long way to mitigate the deflection and was most definitely worth the $5 fix! Thanks for the idea, SeniorSitizen!!
Nealtw likes this.
The Following User Says Thank You to DanoMH For This Useful Post:
SeniorSitizen (05-18-2018)
Grinding concrete that has self leveling on BlueBSH Concrete, Stone & Masonry 2 10-16-2013 09:51 PM
Removing concrete sealant and leveling Leisha70 Flooring 3 08-04-2012 11:06 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
hydraulic cement? leveling concrete? chobio Building & Construction 1 06-28-2011 05:07 PM
Leveling concrete slab acerunner Building & Construction 13 10-06-2010 07:25 AM
