Advise Needed On Insulating Slab For Radiant Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-05-2015, 10:22 AM   #1
Rewards Points: 2
Advise needed on insulating slab for radiant flooring
Dear DIY pros,
I'm about to finish my basement and I have a few questions on what is the proper way to insulate an existing slab.
The tasks at hand are:
1- self-level the existing slab
2- insulate / thermal barrier installation
3- install electric radiant wiring
4- tile
I've researched for the proper insulation to use over slab, but couldn't find a definitive "proper" solution that made sense.
I found "bubble wrap" type [insulation/radiant barrier] that seem to be a good idea in keeping the heat above the slab, but considering that I'll be tiling over this, I'm afraid that the thinset/mortal will crack since the bubble-wrap is not a stable base for tiling.
The only solution I'm considering is a "cork" base/isolator which seem like a better choice under the tile.
Does anyone know of a better product I can use for this application?
Any suggestions are appreciated.
Sam
Hoggie52 is offline   Reply With Quote
Slab help needed gjones Concrete, Stone & Masonry 1 10-06-2012 03:51 PM
insulating slab and drainage toolbelt Tina Building & Construction 9 09-11-2010 08:20 PM
insulating a slab w/o footer for greenhouse dc loud Building & Construction 2 04-17-2010 08:04 PM
Basement Floor Finishing, Advise Needed dbbyleo Flooring 5 04-25-2008 12:32 PM
wood flooring over slab foundation la15ota Flooring 3 03-25-2006 03:49 PM
