7" Wide Engineered Hardware - Nail? Glue? Both? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SPS-1
Old 06-21-2018, 07:59 PM   #1
Rewards Points: 12
7" wide engineered hardware - Nail? Glue? Both?
We purchased 7" wide engineered hardware with tongue and groove installation to put on our raised wood sub floor house in California. We would like to put a 3 in 1 vapor barrier underlayment but the manufacturer website suggests to glue and nail floors wider then 6". If we glue it, we would not be able to use the underlayment.
Does anyone have any experience or knowledge to share on how we should install given these facts?
Flooring is City Expressions by Medallion.
hiyaluv is offline   Reply With Quote
Old 06-21-2018, 08:05 PM   #2
retired framer
Rewards Points: 9,060
Re: 7" wide engineered hardware - Nail? Glue? Both?
There are glues that are vapour barrier too, so they claim.
I have seen it used on concrete basement floor below grade. But I can not attest to how well it works.
https://images.homedepot-static.com/...1cded505a6.pdf
Old 06-21-2018, 08:44 PM   #3
Rewards Points: 9,848
I am no expert either, but Neil is right - adhesives designed to be vapor barriers are exactly that. Only thing is, I would suggest Mapei, not HD stuff.
Nealtw likes this.
SPS-1 is online now   Reply With Quote
Old 06-21-2018, 08:53 PM   #4
Rewards Points: 12
Thank you - but wholly smokes that would be expensive to use on 1800sqft!
Also doesnt solve my noise issue being on a raised floor - any ideas for that?
Lets say we did not nail and glue - would this be an issue in say 10 years from now or likely sooner then that?
Old 06-21-2018, 09:04 PM   #5
Home Repairer
Rewards Points: 468
Give us a link to the actual product not just a name. Will give us a chance to investigate better. I can understand nail down, but the glue has me wondering. More information you provide the better.
czizzi is offline   Reply With Quote
Old 06-21-2018, 09:30 PM   #6
Rewards Points: 12
https://nebula.wsimg.com/44f2de86086...&alloworigin=1
Thank you!
Old 06-21-2018, 09:37 PM   #7
Home Repairer
Rewards Points: 468
Glazed over your link, can you zero me in on where they tell that flooring greater than 6" can not be floated. Would save me some time. Give me page number and approximate paragraph.
Old 06-21-2018, 09:42 PM   #8
Rewards Points: 12
https://www.medallion1.com/city-expr...medallion.html
7" wide engineered hardware - Nail? Glue? Both?-_storage_emulated_0_android_data_com.samsung.android.messaging_files_20171029_131558001_15263474.jpg
Old 06-21-2018, 09:46 PM   #9
Rewards Points: 12
Pg 5, right column "Nail/Staple + Glue Installation Instructions"
Old 06-21-2018, 10:31 PM   #10
Home Repairer
Rewards Points: 468
Based on manufacturer installation instructions, it is a glue/nail down procedure and not a floating floor procedure. As you have not installed yet, you have the opportunity of returning you current product and looking into something without such restrictions. Step down to to 5 of 6 inch width and you don't have these restrictions.
Old 06-22-2018, 04:57 AM   #11
Naildriver
chandler48's Avatar
Rewards Points: 1,932
Maybe I missed something. "Installation: Staples + Glue, Glue Down or Float."
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-22-2018, 05:42 AM   #12
http://www.mapei.com/public/COM/prod...ECO_995_EN.pdf
Not cheap.
Old 06-22-2018, 04:36 PM   #13
Rewards Points: 12
LOL - Yes Chandler, you missed the whole section below that header stating when to use each.
Thanks for the suggestions everyone - we decided to stick to the manufacturers suggestion and are praying its all done before our move in date next week!
Old 06-22-2018, 04:57 PM   #14
Naildriver
chandler48's Avatar
In post #8? I just read it 4 more times and didn't see anything. Sorry
Larry......
Tags
7" wide , engineered hardware , glue and nail floors , tongue and groove
need pattern to lay Random lengths of 5" wide engineered wood Rayann Flooring 0 02-13-2011 03:01 PM
engineered flooring-gap along last wall too wide golfgirl Flooring 5 12-17-2010 08:14 PM
No glue vinyl flooring in a wide room? BizeeB Flooring 1 11-23-2010 08:50 AM
Reusing solid oak planks for closet - nail or glue? spidrw Flooring 2 10-19-2010 04:27 PM
Nail and Glue? Bpawb Flooring 6 07-10-2008 08:31 PM
