4" Wide Hardwood - To Glue Or Not - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2016, 09:28 AM   #1
Rewards Points: 438
4" wide hardwood - to glue or not
Goodmorning,
We are planning to do 4" wide red oak hardwood throughout the above grade floors. This will be site finished work (ie not pre finished). The builder is asking whether I want the floors to be glued or not.
I thought gluing would be required in addition to nailing of course when you are installing 5" or greater width.
Is there benefit to gluing narrower hardwood? Obviously he is going to charge me more to do gluing.
Many thanks!
sbkim is offline   Reply With Quote
Old 02-17-2016, 09:56 AM   #2
Rewards Points: 17,914
What's the manufacture of the flooring suggest?
Follow there install directions to a tee or there's no warranty.
Old 02-17-2016, 10:05 AM   #3
Rewards Points: 438
What's the common practice on 4" floors (real hard wood floors)? Is it common to see them nailed and glued on plywood?
Old 02-17-2016, 08:49 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
It's not common to nail and also glue 4" hardwood. But, the answer to Joe's question is much more relevant then what is done in general. However, if it is beneficial to glue the wood, I'd want to know which method and what type of adhesive the installer uses.
I have a feeling this builder/installer combo do not allow the flooring to acclimate correctly and therefore suggest the glue. Just an educated hunch.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-18-2016, 06:51 AM   #5
Rewards Points: 438
Thank you both for the replies. My builder isn't proving me much info but I will continue to probe starting with what the manufacture is stating and etc.
Builder was commenting that it's advisable to glue and nail and that I should pay extra for the gluing...
Old 02-18-2016, 11:32 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 750
Well, of course you should pay for the gluing if you decide to take their advice. Check with the manufacturer, but then make sure they acclimate and install per the directions.
If the builder and installer do their job right, this advice may not be necessary, but I give them credit for informing you that it might be beneficial.
Jaz
Old 02-19-2016, 05:06 AM   #7
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I have worked in a ton of new homes being built, both average and high end homes and never saw 3/4 oak flooring glued at any width( not that it cant be done??)..I would ask to see manufactures install instructions or the brand of flooring you specified and contact them direct for your answer...could be he is looking to eliminate any future squeaks..and make sure the oak sits in the house for a minimum of several weeks, unwrapped and either unstacked or stickered between bundles...
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
sbkim (02-19-2016)
Old 02-19-2016, 05:13 PM   #8
Rewards Points: 438
Are there any detrimental effects from nailing and gluing other than costs? Again, i will double check what mfg says.
Old 02-22-2016, 11:57 AM   #9
gluing real wood flooring to subfloor
Gluing wood floors is a tricky thing. The problem is that boards expand and contract across their width, but not along their length. Plywood (subfloor) does not do this. If you glue down 2 1/4 wide hardwood strips like you would glue down tile or something (mastic with a trowel) then Bad Things will happen. The wood will shrink and expand with changing humidity, and will do so with great force. It can warp the subfloor, even pulling the nails from the joists or delaminating the plywood, or at least split / buckle the flooring.
Wider boards make the problem worse.
Tongue and groove flooring nailed in the tongue normally avoids this problem by being fixing the tongue to the floor but allowing the board to expand and contract over it's width since the groove end is allowed to move, at least to freely contract. It's limited in expansion, but normally the wood looses moisture and contracts more than expands, and the wood does have a little give by compressing if it expands a little.
Having said this, I have successfully glued flooring to a good plywood base by running a thin strip of somewhat flexible wood glue down the center of the plank while stapling (flooring staples) the tongue. The wood is mostly fixed in place at the center of the board, and the staples are flexible enough that the slight movement from expansion and contraction over 1/2 the width of the board is tolerated by the staples. Not yet sure this is better than just staples, though.
I did try gluing 4 inch wide pine T&G boards to 3/4 inch plywood screwed to 2x12 12 inches on center once, under the assumption the subfloor was strong enough to keep things flat. I was wrong.
This is different with engineered flooring, because that's essentially plywood and very stable.
garycarroll is offline   Reply With Quote
The Following User Says Thank You to garycarroll For This Useful Post:
sbkim (02-22-2016)
Old 02-22-2016, 08:07 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 750
Sorry garycarroll, I can not agree with much of your theory, especially the first paragraph.
The manufacturers' instructions to nail/staple & glue wood 5" and wider (some say 4") is to help prevent the boards from cupping as much or at all under humid conditions from below the floor. The planks should be glued using a trowel covering 100% of the floor. If you'd notice the glue is a bit rubbery and it gives with the wood as it moves with the seasons, then pulling it back.
I highly recommend everyone follow the manufacturers directions for their particular species of wood.
Jaz
Floating vs Glued Hardwood Install? dgarstang Flooring 13 11-11-2015 01:19 AM
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Leveling hardwood for laminate Fred_ Flooring 3 03-23-2013 11:22 AM
Stripping tar glue off c1915 Hardwood Floor Master Brian Remodeling 4 12-02-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
