Staining And Painting Wood Projects - Project Showcase - DIY Chatroom Home Improvement Forum
Old 10-09-2019, 08:35 AM   #1
Rewards Points: 12
Staining and Painting Wood projects
I have been building wood games for a little while now and I have changed the way I do things but I am still not satisfied. I switched over to a dye stain because tape would not pull up the stain. I usually tape off a picture area, then I paint it using acrylic interior paints on top of that. I finish by applying a few layers Polyacrylic top coat on top of that. Recently, I am noticing the lighter shade of paints are showing the stain coming through. How do I fix this? Do I put a sanding sealer on top of the stain? Will tape pull up the sanding sealer? Any advise would reduce my stress level!
KW346 is offline   Reply With Quote
Old 10-09-2019, 12:30 PM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,392
Re: Staining and Painting Wood projects
You may want to post in the painting forum for some results.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
KW346 (10-09-2019)
Old 10-09-2019, 12:46 PM   #3
Rewards Points: 12
Thank you for the suggestion!
Old 10-11-2019, 02:36 AM   #4
Rewards Points: 6
Thanks, it's very helpful.
ljch1210 is offline   Reply With Quote
Tags
painting advice , stain wood
