Partial Earth Sheltered Home - Project Showcase - Page 15 - DIY Chatroom Home Improvement Forum
Like Tree90Likes
Old 08-06-2016, 11:22 AM   #211
Rewards Points: 7,467
Re: Partial Earth Sheltered Home
Originally Posted by ddsrph View Post
For some reason I can only post one photo at a time.
Unlike some sites this site only allows one upload at a time but I have always been able to attach multiple images to a post. Try just uploading one and then another.
Nice looking work. I will need to start at the begining and work my way through the thread.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
ddsrph (08-06-2016)
Old 08-06-2016, 10:22 PM   #212
Rewards Points: 14
The curb looks very nice ddsrph, and that color of pea gravel looks great with the color of the house.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
ddsrph (08-07-2016)
Old 08-29-2016, 11:53 AM   #213
Rewards Points: 877
I just got the plumbing done, using CPVC. I like the German brand PEX that uses the expand plus slide on ring system and can change to this later if I want to. All the plumbing is external and except for the utility room hidden by cabinets. The bathroom is between the utility room and kitchen so I ran conduits under tub shower to later slide the supply lines thru, kitchen lines are all under sink cabinets and then back thru wall to bathroom sink and commode. On the supply from street I put the 3/4 inch inside a 1 1/2 inch conduit so no need to ever dig up yard again. I had to seal the conduit on the inside as it could be a water pipe itself if the inter 3/4 inch line ever leaks. I used a double ended rubber gasket pipe coupler for this seal.
BigJim, gma2rjc and 123pugsy like this.
ddsrph is offline   Reply With Quote
Old 08-29-2016, 11:13 PM   #214
Plumber
TheEplumber's Avatar
Rewards Points: 888
Piping looks real nice. I guess CPVC is the pipe flavor Tennessee prefers. It's not the first time I've seen it there. Do you have an isolation valve on the heater?
The Following User Says Thank You to TheEplumber For This Useful Post:
ddsrph (08-30-2016)
Old 08-30-2016, 06:56 AM   #215
Rewards Points: 877
There is a brass shutoff valve just before the expansion tank on the cold water side. I welded up a couple of steel brackets to support the expansion tank and other pipes. The only cut off valves on the hot water side are at the kitchen and bsthroom sinks. Here is a photo of the pipes that will be under the kitchen sink. They are fed from the supply pipes that run under the tube shower, feed back thru the wall to supply the bathroom sink and commode.
Old 08-30-2016, 11:08 AM   #216
sleepyg's Avatar
Rewards Points: 30
Just wondering is that galvanized just after the ball valve?
I used to have a handle on life.........................................But it broke!
sleepyg is offline   Reply With Quote
Old 08-30-2016, 12:42 PM   #217
Rewards Points: 877
It is galvanized. I wanted something strong to hang the expansion tank off of.
Old 09-05-2016, 02:19 AM   #218
The Painting Man
Rewards Points: 76
Wow. Nice job this looks really cool from the first images. Really impressed
BocaPaint is offline   Reply With Quote
The Following User Says Thank You to BocaPaint For This Useful Post:
ddsrph (09-05-2016)
Old 09-05-2016, 02:19 AM   #219
The Painting Man
Rewards Points: 76
oh and to post more than one photo maybe try imgur and then share the link with us
ddsrph (09-05-2016)
Old 10-24-2016, 04:32 PM   #220
Rewards Points: 877
All I have left is flooring, interior doors and trim. I have tried to get most of the outside work done with the good fall weather. I have poured the rest of the sidewalk using concrete I mixed in a HF mixer which is working well. I hope to move in then build the rest of the garage and small deck.
JM
Old 11-21-2016, 09:10 AM   #221
Rewards Points: 877
I have finally gotten all the curb poured and the pea gravel in place. The HF concrete mixer worked very well and saved a lot of money. All the Pergo is down and a bunch of tile remains which I dread but have a heated house to work in this winter. Tile , interior doors, and trim left for winter plus I plan to make my own hickory cabinets using doors purchased on Internet from a company called "Raw Doors" I think they are in Iowa.
JM
gma2rjc and sleepyg like this.
Old 11-21-2016, 09:18 AM   #222
Rewards Points: 877
Three rooms have Pergo from Lowes, Spalted Maple, pattern.
Old 11-21-2016, 10:19 AM   #223
Ole Wood Worker
BigJim's Avatar
Rewards Points: 492
Looks like you got things on a down hill drag now, it really does look good. Those Hickory cabinets are going to look great. It don't look like we are going to have much winter around here this year.
cocobolo likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
ddsrph (11-21-2016)
Old 11-21-2016, 10:03 PM   #224
Rewards Points: 34
Very nice
dhederson is offline   Reply With Quote
Old 11-22-2016, 01:10 AM   #225
cocobolo's Avatar
Rewards Points: 6,498
JM...forgive me for being so late in making an inquiry about a pic you posted on August 29th.
Is there some particular reason that you don't seem to have the expansion tank being supported from below?
I note that you have it hanging off galvanized pipe, but that in turn is attached to plastic on one side and copper on the other. Wouldn't you be a little safer to give the tank some solid support from below?
I must admit I'm just more curious than anything.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
3 phase anyone? Tomkah Electrical 3 01-05-2007 06:18 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
