Ongoing Closet Build After Flipping Staircase - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-04-2016, 11:38 PM   #1
Rewards Points: 396
ongoing closet build after flipping staircase
After dealing with difficult basement access for a few years, we decided to reverse our staircase so that we would eliminate a landing and right turn at the bottom. The original layout was preventing us from getting nearly any furniture downstairs, as well as any long building materials.
Now that we have the staircase reversed, and the hole walled off for a closet, my wife has been wanting me to put in a hall closet system. Here's what I've got so far, with my 1 1/2 year old's help.
This also involved some flooring repair, as the planks that were there were originally cut around the casing and base trim, causing gaps all around. I adjusted everything to go underneath the jambs. Deciding how to deal with the flooring delayed the project by quite a bit.
badtheba is offline   Reply With Quote
Old 01-04-2016, 11:54 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 612
Great job, good use of normally wasted space. You got a precious little helper there also.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-05-2016, 09:56 AM   #3
sleepyg's Avatar
Rewards Points: 30
Good help is hard to find! Nice job of letting the little one "help".
I used to have a handle on life.........................................But it broke!
sleepyg is offline   Reply With Quote
Old 01-05-2016, 11:19 PM   #4
Rewards Points: 22
Very nice use of the space at the bottom.
Your little helper is a cutie pie!
gma2rjc is offline   Reply With Quote
Old 01-06-2016, 12:52 AM   #5
Rewards Points: 396
As the closet is over 34" deep from the back of the door jamb, I'm also working on a false back with hidden storage behind it. I used the front 24" of depth for the coat closet portion. I'm going to have a narrow door of some sort behind the coats and possibly drywall everything, and drywall over the door so it blends in.
The Following User Says Thank You to badtheba For This Useful Post:
gma2rjc (01-06-2016)
Old 01-06-2016, 01:19 AM   #6
Rewards Points: 46
Excellent job. Very creatively you've used the extra space for a good purpose. I like the overall improvement.
melving.crane is offline   Reply With Quote
Old 02-16-2016, 11:36 AM   #7
Rewards Points: 428
all the pictures are dead
clawlan is offline   Reply With Quote
Old 02-16-2016, 01:26 PM   #8
Rewards Points: 396
You're right. Apparently I'll have to go back to photobucket, which I hate.
http://googlephotos.blogspot.com/?hl=en_US
Old 02-16-2016, 01:29 PM   #9
Rewards Points: 396
here's the album in order on Google Photos... I'll have to figure out where to host my stuff permanently and fix/edit some posts.
https://goo.gl/photos/rGVJrTBWSiYHARJu6
Old 02-16-2016, 02:14 PM   #10
Rewards Points: 428
I've always used imgur.com and never had issues.
Old 02-20-2016, 01:11 AM   #11
MACSUGAR's Avatar
Rewards Points: 12
I like the design of its bottom. Good job!
MACSUGAR is offline   Reply With Quote
Closet vs bathroom extension Stephen S. Remodeling 11 03-20-2010 11:01 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
DIY Walk in Closet build bigdonk Building & Construction 11 11-12-2009 07:23 AM
How to design and build attic closet over sloped roof Mendosherman Building & Construction 5 07-09-2009 03:15 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 07:58 PM
