Front Porch Rebuild - Project Showcase - Page 6 - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 07-29-2020, 08:44 PM   #76
kwikfishron's Avatar
Rewards Points: 798
Re: Front porch rebuild
Originally Posted by Nealtw View Post
So we agree on the height of the main deck, you would just come out level with the floor instead of the step down at the door.
Originally Posted by kwikfishron View Post
I'm saying Two steps down...The first step is when you come out of the door onto a landing
Maybe I should have said: 'Down' onto a landing.
kwikfishron is online now   Reply With Quote
Old 07-29-2020, 08:56 PM   #77
retired framer
Rewards Points: 17,006
So two risers, one step. I think we are agreeing
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Jim F (07-30-2020)
Old 07-29-2020, 09:14 PM   #78
Rewards Points: 798
Yes, but I'd like to see the first step out of the door (the landing) be at least 36" deep so it's a comfortable space to stand while you're waiting for someone to open the door.
It (36"+) doesn't have to be but that's what I'd want.
The Following User Says Thank You to kwikfishron For This Useful Post:
Jim F (07-30-2020)
Old 07-29-2020, 09:16 PM   #79
retired framer
Yes I think 36" landing would apply if it is more than a reasonable tread depth.
figure 7-14
Jim F (07-30-2020)
Old 07-30-2020, 07:13 AM   #80
Rewards Points: 472
I definitely want to step down from the door. Also agree that it should be a comfortable distance out say 3 ft. My current plans call for coming 6 ft out from that point but giving that the entire deck is going to be lower I may come out a little further than that. My main concern is I don't want to have four step uo from the ground level up to the deck level like I had before. Removed all the furniture into this house from that approach and it was not fun.
Nealtw likes this.
Jim F is offline   Reply With Quote
Old 07-30-2020, 08:25 PM   #81
Rewards Points: 472
"You would like to build the step frame out of 2x8s @ 7 1/4" This has me a bit confused. If I use 2 x 8s won't my rise be 8 inches? But I have been contemplating building a step frame onto the main deck level.
Old 07-30-2020, 08:40 PM   #82
retired framer
2x8s are around 7 1/4" when they dry out if you but that on the main frame before adding decking the step is 7 1/4 inches and the decking is the same on both.
figure 7-14
Old 07-30-2020, 10:44 PM   #83
Rewards Points: 68
There is a membrane called Resisto 4"wide the made to cover the top of joists before decking goes on This will save your joists from standing water Believe its available at HD as well as Lowes
67IreneRoad is offline   Reply With Quote
Old 07-31-2020, 06:21 AM   #84
Rewards Points: 472
I will be using something like that after finding water damage on the joists in the demo.
