Front Porch Rebuild - Project Showcase - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 06-29-2020, 09:53 AM   #1
Rewards Points: 470
Front porch rebuild
Hi after receiving some ridiculously high estimates on rebuilding our front deck I decided to tackle it myself possibly. First I got a demo this thing to see what I'm dealing with. There is so rot near the front door on a count of it being poorly flashed. This thing is falling apart. it was improperly done in the first place probably by the previous homeowner. We knew at the inspection that it's was poorly done it didn't pass the inspection. But we got a break on the price as a result. Finally doing something about it. I've got estimates ranging from $8, 000 to $18,000 so I think it's time I try to do myself if I can.
Jim F is offline   Reply With Quote
Old 06-29-2020, 09:55 AM   #2
Rewards Points: 470
Can anyone help me figure out how to post pictures from an Android phone?
Old 06-29-2020, 10:13 AM   #3
Rewards Points: 470
Figured it out.
Front porch rebuild-img_20200629_104901_1593443533212.jpg   Front porch rebuild-img_20200629_105547_1593443561496.jpg   Front porch rebuild-img_20200629_104908_1593443582829.jpg
Old 06-29-2020, 10:35 AM   #4
retired framer
Rewards Points: 15,284
Re: Front porch rebuild
Originally Posted by Jim F View Post
Figured it out.
If you are prepared for work and pay attention to the advice you will save lots of cash. I might tie that to the car and take a little dive and see if it just comes away from the house.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-29-2020, 02:15 PM   #5
Rewards Points: 470
It definitely would but probably though the shrubbery.
Old 06-29-2020, 02:19 PM   #6
Rewards Points: 470
Not too much progress today started by removing some of the short decking boards in the railing. Going to try to disassemble it carefully to see if there's framing wood underneath that can be salvaged and reused. But I'm not too hopeful.
Front porch rebuild-img_20200629_113827_1593458268021.jpg   Front porch rebuild-img_20200629_122137_1593458296970.jpg
Nealtw likes this.
Old 06-29-2020, 02:52 PM   #7
Rewards Points: 4,194
When I bought my house in 1980 it had a porch that looked like it was going to fall down. I had a big 4 wheel drive truck that was set up for off-roading with low gears, a modified engine and lockers in both axles. I hooked it to the porch and I couldn’t pull it down. But it was fun trying.
Old Thomas is offline   Reply With Quote
Old 07-01-2020, 10:23 AM   #8
Rewards Points: 470
Couple of more progress pictures I lost yesterday due to having to go to doctor appointments. I'm wondering before I throw all this old Trex out if it's something that could be reused and painted. I've been told it's kind of a first generation Trex it doesn't have a vinyl coating laminated on it like the modern Trex does.
Front porch rebuild-img_20200701_111833_1593616883556.jpg   Front porch rebuild-img_20200701_111852_1593616918550.jpg
Old 07-01-2020, 10:30 AM   #9
retired framer
Maybe.
https://www.trexfencing.com/wp-conte...ting-guide.pdf
figure 7-14
Old 07-02-2020, 09:08 AM   #10
Rewards Points: 470
The more I pull this deck apart the more I say holy F!
Front porch rebuild-img_20200702_100557_1593698835533.jpg   Front porch rebuild-img_20200702_100547_1593698859179.jpg   Front porch rebuild-img_20200702_100544_1593698880874.jpg   Front porch rebuild-img_20200702_100610_1593698900019.jpg
Old 07-02-2020, 09:12 AM   #11
dj3
Rewards Points: 1,316
Demolish everything.
Even if you buy all new materials, you will be ahead of the estimates.
dj3 is offline   Reply With Quote
Old 07-02-2020, 09:15 AM   #12
Rewards Points: 470
Here they put two, here they put one, here they put none.
Front porch rebuild-img_20200702_101307_1593699256851.jpg   Front porch rebuild-img_20200702_101310_1593699279975.jpg   Front porch rebuild-img_20200702_101318_1593699302285.jpg
Old 07-02-2020, 09:49 AM   #13
Rewards Points: 470
For reasons I don't understand, they seem to have actually properly through bolted on the side of the deck. However they did not flash at all not even the cobbed together pieces that they had on the other side.
Front porch rebuild-img_20200702_104614_1593701269075.jpg   Front porch rebuild-img_20200702_104624_1593701301722.jpg
Nealtw likes this.
Old 07-03-2020, 06:30 PM   #14
Rewards Points: 470
Difficulty loading pics today. Site froze my phone.
Old 07-03-2020, 06:35 PM   #15
Rewards Points: 470
Trying to show where the deck failed the most near the entry. Water got trapped at the wedges any called some root they're too. How does one protect the framing under the deck boards to prevent this from happening?
Front porch rebuild-pano_20200703_114043_1593819082361.vr.jpg   Front porch rebuild-img_20200703_112615_1593819124013.jpg   Front porch rebuild-img_20200703_105148_1593819164578.jpg
