Cathedral Ceiling For The Master Bedroom - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree10Likes
Old 08-30-2019, 09:59 AM   #16
Rewards Points: 190
Re: Cathedral ceiling for the master bedroom
Thank you!
Itís could be done only by using your own time and sweat. I canít even imagine how to price something like that. So far it took me over three month working alone every weekends. I knew itís going to be a vary labor intensive when I design this thing, but Iím not sure if Iím going to do this ever again
tdisss is online now   Reply With Quote
Old 08-30-2019, 10:56 AM   #17
Rewards Points: 6,144
When I first started reading your thread I missed that it was a completed project and started my notes with the question, wouldn't it be easier to remove that section of the roof and install purpose built trusses? Then I realized it was a done deal so kept my mouth shut. Now at the end I hear you questioning the time required so I'll ask, Would it have been easier to remove and rebuild that area??
Note, I think it looks fantastic and sometimes people just like climbing mountains when all there is at the top is a view that few will ever see.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 08-30-2019, 11:38 AM   #18
Rewards Points: 190
Hi, Bud
You are correct, something like this is easier to accomplish with a conventional roof framing, however to remove the portion of roof and engineering trusses is unfeasible in this case. The 2 story building is not designed for the long ceiling joist span at 2nd floor level, the bearing walls and point load posts needs to be constructed which would involve the whole house rebuild. These particular trusses carries the roof over two adjourning rooms and master bathroom.
The idea of this project is to demonstrate that interesting ceiling could be done even in the house with engineering truss roof construction.
Bud9051 likes this.
Old 09-03-2019, 09:19 AM   #19
Rewards Points: 190
Tiles installation continue. In order to reduce tile cracking I taped the face of tile with heavy-duty stucco tape.
Nealtw likes this.
Old 09-03-2019, 09:29 AM   #20
Rewards Points: 190
All tiles installed. Edges have been trimmed and polished. Luckily, the marble tile are easy to cut and grind. There is lot of dust, thoughÖ
Getting ready for grout
Old 09-10-2019, 08:01 AM   #21
Rewards Points: 190
Grout and paint touch up are done. No more dust!!!
Nealtw likes this.
Old 09-10-2019, 08:08 AM   #22
Rewards Points: 190
I installed the recessed ethanol fireplace. The manufacturer's specs was incorrect!! I had to modify the finished opening on the fly to adjust depth for the proper bracket placement.
Old 09-10-2019, 08:20 AM   #23
Rewards Points: 190
Next is the intallation of "no gap" TV bracket and receiver.
This TV features specially designed custom TV frame and displays artwork! It looks like beautiful picture frame hanged on the wall.
Old 09-14-2019, 10:03 AM   #24
Rewards Points: 190
Project is complete.
Cathedral ceiling for the master bedroom-277d9e9f-41d5-498c-8046-2e69704f9914_1568473288746.jpg   Cathedral ceiling for the master bedroom-9e2d0fbc-f5fd-488b-9b58-834804319dc7_1568473315013.jpg   Cathedral ceiling for the master bedroom-5e77d603-e8e0-45fe-a35a-ec46457cd8af_1568473341252.jpg   Cathedral ceiling for the master bedroom-8b4c596f-0cbc-495e-87af-266159331c00_1568473364865.jpg
SPS-1 likes this.
Old 09-14-2019, 10:19 AM   #25
Just a question and it may have been addressed, sorry, but locating the flat screen directly above the fireplace is guaranteed to provide some hot pictures, pun intended.
I took some infrared images of the wall temperatures above a standard baseboard hot water radiator and that heat hugs the wall as it is pushed up. In terms of electronics, they don't like heat.
Any thoughts?
Bud
Old 09-14-2019, 10:32 AM   #26
retired framer
Rewards Points: 20,636
Any thoughts?
Bud
I am not sure the brand but we found it in one set of instructions
The bottom of the mantel is 14" above the fireplace and should be 10" deep.
I think that would be less for a TV mounted flat to the wall.
Do not use flat bottom gables with scissor trusses.
Old 09-14-2019, 11:01 AM   #27
Agreed, a mantel would help slightly but I don't see one here and I don't think the op would like a 10" deflector. With all of the posts we see where people like that location I'm surprised the mfgs aren't providing more guidance. Of course that might affect sales so I don't expect it anytime soon.
Bud
Nealtw likes this.
Old 09-14-2019, 01:11 PM   #28
Rewards Points: 190
I completely agree that mounting tv directly above the conventional gas/ wood fireplace is not a good idea. However the fireplace we have installed just a decorative ambiance fireplace. We tested this fireplace before we mounted tv above. Even after an hour of continuous burning the stone tiles above the fireplace are cold to touch. The metal heavy duty box did a good job to deflect heat toward the room.
Nealtw likes this.
