Bought House Sight Unseen - Renovating - Project Showcase - Page 10 - DIY Chatroom Home Improvement Forum
Like Tree143Likes
Old 06-10-2019, 12:34 PM   #136
Rewards Points: 394
Re: Bought house sight unseen - Renovating
This is one of the tasks that I would not have undertaken if my wife and I decided we were not going to move into this home earlier. The previous ceiling was just fine. Hopefully yall can view the photos.
Old ceiling gone. New boxes mounted/wired for lights. I had to scab in some 2x2s to the bottom of the ceiling joists to cover a gap between the ceiling joists and siding.
I wanted a decorative design...but I was a bit lazy and wanted to reduce the number of cuts. Another design has the wainscotting panels centered along both the x and y axis, thereby having a full panel run down the center and approx 1/2 panels on either side.
The (nearly) finished product.
The next several months are going to be dedicated to only outside projects. Painting, garage roof, rear porch, installing a AC unit, etc. Goal is to have all outside work done before weather changes in fall and then finish up the inside stuff.
Fisher1871 is offline   Reply With Quote
Old 06-10-2019, 05:29 PM   #137
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
Nice Job....
MTN REMODEL LLC is offline   Reply With Quote
Old 06-21-2019, 03:25 PM   #138
Rewards Points: 252
WOW, thats dedication. I salute you.
lug-nuts is offline   Reply With Quote
Old 11-01-2019, 04:05 PM   #139
Rewards Points: 394
The last few outside jobs are being buttoned up before winter really sets in again.
I had hoped to get all outside work completed this past summer, but I didn't have the time. Additionally, I struggled to make a decision concerning the garage.
The garage
This garage is attached to the house. The kitchen door/porch is integrated into the flat roof on the garage.
I started with the kitchen porch. The porch roof was cockeyed and everything below the porch box beam was rotten.
Demo
The flat garage roof presented challenges. In order to meet code, I need to install three new more robust steel I-beams or install engineered wood I-joists. Due to the amount of rot, almost no part of the current roof was salvageable.
It was going to be $25k+ all in - and that's IF I worked fast enough for a local roof to install new EPDM roofing before winter hit.
After much contemplation, I am going to detach the garage from the house. This weekend I will install 6x6 posts to support kitchen porch roof and build a new wood porch for the kitchen door.
The detached garage will eventually be converted into a mother-in-law suite with a 1 or 2 bedroom apartment.
123pugsy and Nealtw like this.
Old 11-01-2019, 04:15 PM   #140
retired framer
Rewards Points: 4,330
I hadn't realized that was the same house we have been watching you fix up.
Do not use flat bottom gables with scissor trusses.
Old 11-01-2019, 04:18 PM   #141
Rewards Points: 394
It's been a lodestone, no question. The experience is invaluable though.
Nealtw likes this.
Old 11-01-2019, 06:13 PM   #142
Rewards Points: 680
Mother in-law suites should be built at least 2 states away.
123pugsy and Fisher1871 like this.
LawnGuyLandSparky is offline   Reply With Quote
Old 11-11-2019, 03:49 PM   #143
Rewards Points: 394
My first foray into deck framing and large posts.
I'm not completely happy with how it turned out, definitely due to my inexperience in planning. Plus it's an old home and I'm working around a lot of poorly thought out projects from the last 100 years. Once I was committed, I was committed and wanted things done in a timely, and more importantly, SAFE manner.
Original deck/deck roof.
As one can see, there is a pretty substantial sag on the right hand side. It was about 6 inches or so lower from left to right.
I'm removing the garage entirely. There were so many things wrong, I couldn't see a way to tie everything back in. Now that I have the deck roof posts installed, I'll remove the rest of the old joists, remove the steel I-beams, and knock down the block walls.
When I (re)build the garage I'll work with a clean canvas.
New 6x6s installed. Again, not perfect and I would do some things differently. Also, while it doesn't seem that high - it sure felt that way when I was trying to manage a 16 foot 6x6 (~170lbs) from 16 feet or so in the air.
The photo or maybe the angle of the garage roof line makes it look like the 6x6s are a bit out of plumb, but I checked and rechecked. They are in.
Old 11-11-2019, 04:05 PM   #144
retired framer
Is there enough to lag the ledger to or can you thru bolt to the rim?
Old 11-11-2019, 04:13 PM   #145
Rewards Points: 394
I'm going to remove the old shiplap siding (I think that's the correct term). Flash it and attach the ledger using lags to the balloon framing. There is no rim board (again, I think that's the correct terminology) behind the shiplap, just the 2x4 framing on top of a sill plate.
Old 11-11-2019, 05:07 PM   #146
retired framer
But the joists land on the steel beam?
Old 11-11-2019, 06:19 PM   #147
retired framer
so when you don't have a ledger you can trust you line up the joists with the joists inside so you can add a few of these. They tie into the joists inside.
Old 11-11-2019, 07:00 PM   #148
retired framer
I have tried to answer as many questions as I can with pictures.
Bought house sight unseen - Renovating-fis-8.png   Bought house sight unseen - Renovating-fis-7.png   Bought house sight unseen - Renovating-fis-6.png
Fisher1871 likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Fisher1871 (11-12-2019)
Old 11-11-2019, 08:10 PM   #149
retired framer
stringers are cut out of 2x10, we often put a painted 2x12 outside that to make it look finished.
Old 11-12-2019, 02:02 PM   #150
Rewards Points: 394
I'm going to have to digest this a bit further. I think I get it - and I like it! Thank you again!
Nealtw likes this.
bought a old lake house horshak New Member Introductions 12 06-14-2014 06:09 PM
Renovating house, replace all plumbing too??? Huggins90 Plumbing 11 01-09-2013 11:09 PM
just bought a house. need some advice! 19mquinn79 General DIY Discussions 18 03-04-2011 04:51 PM
Just bought a house with Travertine floors. Can the marble be refinished? Cost? Waterfowler Flooring 17 09-22-2009 03:00 AM
backing out of the house i bought this old house Building & Construction 9 11-19-2005 01:56 PM
