1st Attempt At Remodel - Project Showcase - DIY Chatroom Home Improvement Forum
Old 03-04-2016, 06:06 PM   #1
Rewards Points: 14
1st attempt at remodel
I have done a lot of odd and end stuff helping people, plus owning a new house. But 8/2014 I bought a house that was deemed "liveable" and not any more then that on appraisal. Have done ALOT of work in last year and a half. Still got a lot more. Here are some before and after shots of what I have done.
Entrance shortly after we started remodel
Now
Living old
Now
pomaikai is offline   Reply With Quote
Old 03-04-2016, 06:13 PM   #2
Rewards Points: 14
Old 03-04-2016, 06:19 PM   #3
Rewards Points: 14
Wasted space...Hall
Gone, linen closet(3'x3.5'), dry bar, new opening to master off living room
Old 03-04-2016, 06:21 PM   #4
Rewards Points: 14
Old bath
The Following 2 Users Say Thank You to pomaikai For This Useful Post:
123pugsy (03-08-2016), Gymschu (03-04-2016)
Old 03-04-2016, 06:38 PM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
very nice work!!
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
kwikfishron (03-04-2016)
Old 03-04-2016, 07:29 PM   #6
kwikfishron's Avatar
Rewards Points: 178
So where did the space for the alcoves come from (What did you lose on the other side of the wall)?
kwikfishron is offline   Reply With Quote
Old 03-04-2016, 07:32 PM   #7
Retired Moderator
Rewards Points: 7,174
Dramatic improvements.
Old 03-04-2016, 10:09 PM   #8
Rewards Points: 14
Behind the living room wall was just a really long Hall to master. So I opened up the master to living room with a tiny little Hall. Center of the hall became dry bar. Hall closest to front was turned into a linen closet. Old linen was a tiny 2'x2'. It was taken out and the second bedroom door was moved over. I will take pics of it as that room is the last room I need to finish. I removed closet from that room as well because the electric panel was in it and no longer code. I figured it's easier to move closet then electrical panel.
The Following User Says Thank You to pomaikai For This Useful Post:
kwikfishron (03-05-2016)
Old 03-06-2016, 12:33 AM   #9
Rewards Points: 14
Kitchen is my current project. Not even close to done, but progress. I try to keep it functional at each step.
123pugsy (03-08-2016), sleepyg (03-18-2016)
Old 03-06-2016, 09:54 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,446
Looking great!!!!
Remodel Can Housings For Plaster Ceilings BigJimmy Electrical 4 04-21-2014 07:26 AM
Anyone real familiar with Halo IC 6" Remodel housing? zr800 Electrical 3 01-14-2014 01:01 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 06:54 AM
remodel box for wall fixture DIYGST Electrical 4 01-02-2010 04:21 PM
