Yikes... Dryer Ain't Working! - Appliances - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By de-nagorg
Old 05-29-2018, 10:33 PM   #1
Rewards Points: 56
Yikes... dryer ain't working!
Bought this store model, GE flat back dryer 4yr ago at sears outlet for like $400. It isn't working today.
I turn the knobs and ain't working. Lights on inside dryer though. Circuit breaker didn't trip.
Is it something i can open the top panel and see if there's a connection missing etc?
Any recommendations?
Thx....
Sent from my SM-N950U using Tapatalk
miserkris1 is offline   Reply With Quote
Old 05-29-2018, 11:15 PM   #2
JUSTA MEMBER
Rewards Points: 1,062
Re: Yikes... dryer ain't working!
Define " not working", no heat, or no tumble.
Download a schematic for that make and model, before attempting to repair, take pictures of each step disassembling it, that way you have a picture of how it's supposed to be when assembling it again.
Need to look for internal fuses (blown?), loose wires, heating element intact, dust / dirt buildup, worn drive belt, drum rollers, lot's of things.
ED
miserkris1 likes this.
de-nagorg is online now   Reply With Quote
Old 05-29-2018, 11:39 PM   #3
Rewards Points: 56
ED
Thanks, will do!
It isn't working meaning no hum/ noise,no tumble, no heat.... only the light is working
Old 05-30-2018, 02:39 PM   #4
Rewards Points: 949
Check the outlet for 240v line to line.
DanS26 is offline   Reply With Quote
Old 05-31-2018, 07:22 PM   #5
Rewards Points: 56
I did....i mean the lights on inside when doors open....
You mean check inside with a tester
Old 05-31-2018, 07:39 PM   #6
retired framer
Rewards Points: 4,498
The light is 120 volts the rest of the dryer may need 240 to operate so you want to make sure you are getting 120 on both sides or 240 between the two. You can check the outlet and where the wires go into dryer.
Old 05-31-2018, 11:55 PM   #7
JUSTA MEMBER
What type of wall outlet do you have to plug into?
A standard 110V, or a 240 V.
I have seen a 240 V outlet, lose one leg, because someone left the wirenut loose.
ED
Nealtw likes this.
Old 06-01-2018, 10:28 PM   #8
Rewards Points: 56
ED
It's 240v outlet been in use for many years.
I have a cheap harbor freight multimeter...
Can i use it to test? If so what setting?
Thx
Old 06-01-2018, 10:43 PM   #9
JUSTA MEMBER
A multi-meter is the correct tool.
Use the V AC setting high enough to cover the 240V.
insert the probes on the meter in the correct holes. , then use the test probes The negative on your meter to the ground hole of the outlet, and the positive to one of the slots, and get a voltage reading. then the positive lead to the other slot.
Should get 110 on each side. May be 120 V, depending.
If they are different, there is a loss somewhere in the circuit.
Now turn off the breaker and remove thee cover, look for a loose wire nut, or burned wire, or other wrong appearance.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
miserkris1 (06-02-2018)
Old 06-02-2018, 07:59 PM   #10
Rewards Points: 56
ED
Well i better be safe than sorry! Are my settings right? Thanks!
Old 06-02-2018, 11:24 PM   #11
JUSTA MEMBER
That is correct for that meter.
If the meter is a good one, it will give you the results of the circuit.
ED
Dryer Vent Problems - Small Space moose8721 Appliances 5 10-30-2013 11:20 PM
Gas Dryer - Install Flex Line and Also No Heat mark2741 Appliances 8 07-05-2011 01:10 AM
Samsung Dryer Issue?? cbzdel Appliances 4 05-31-2011 03:47 PM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 03:16 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
