Would Uninsulated Dryer Vent Melt Wall Insulation? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-19-2016, 03:16 PM   #1
Rewards Points: 394
Would uninsulated dryer vent melt wall insulation?
I'm residing the house and adding insulation to the walls that previously haven't had any. Pulled out the outside dryer vent, and now need to put it back, at least temporarily to do laundry. Just want to make sure that the heat won't hurt the regular wall insulation for the time being, till I wrap the vent in proper insulation.
Dixon12 is offline   Reply With Quote
Old 07-19-2016, 03:21 PM   #2
Rewards Points: 4,366
Re: Would uninsulated dryer vent melt wall insulation?
My gas dryer punches out a side wall of the house and is in contact with plastic vapor barrier, fiberglass and foam insulation and I have no issues.
stick\shift is offline   Reply With Quote
Old 07-19-2016, 09:28 PM   #3
Rewards Points: 1,880
Gas dryer vents are rarely insulated, I would only consider it if I had an extremely long run up into an attic.
ChuckF. is offline   Reply With Quote
Old 07-19-2016, 11:09 PM   #4
Rewards Points: 394
It's an electric, but it gets pretty hot. Full load dries completely on lowest setting. and it's vented through the wall, about 4 feet of duct or so.
How to vent dryer in 2x4 wall? isuhunter General DIY Discussions 29 03-17-2016 01:23 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Dryer vent in middle of wall? kwerk Building & Construction 2 08-21-2010 04:15 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
