Whirlpool Gas Oven Will Not Stay Hot - Appliances - DIY Chatroom Home Improvement Forum
Old 01-19-2016, 05:51 PM   #1
Rewards Points: 4
Unhappy
Whirlpool gas oven will not stay hot
I have a Whirlpool Super Capacity 465 Accubake System range/oven. The burners work fine, but when I use the oven, it will usually preheat and stay hot from anywhere from 1/2 an hour or even longer, but usually stops heating without being turned off. The broiler works fine and I'm not sure about the self-clean feature. I don't think it's kicking on, although the panel lights all say everything is working. I wonder if this is worth fixing, or would I be better off buying a new appliance? Thanks to all who respond.
RochelleF is offline   Reply With Quote
Old 01-19-2016, 10:58 PM   #2
Rewards Points: 286
Hey Rochelle, I found a thread with similar problem to yours. Could be ignitor, gas valve or circuit board. Apparently, your gas oven (assuming it's gas here), must detect a persistent oven flame or it shuts down.
Here is the link and comment on this oven being cost effective to fix (scroll down):
http://www.amazon.com/Whirlpool-9758...ews/B0053Y2I8U
Good luck.
ProGreen is offline   Reply With Quote
The Following User Says Thank You to ProGreen For This Useful Post:
RochelleF (01-25-2016)
Old 01-25-2016, 09:35 AM   #3
Rewards Points: 4
Thank you very much!!
my whirlpool range/oven , the oven won't heat up but everything else is working fine prattantina Appliances 3 11-18-2012 10:30 PM
Whirlpool oven igniter JIM FLYNN Electrical 3 11-16-2012 08:19 AM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 06:32 PM
Whirlpool Oven removal k4thdan Appliances 4 11-25-2010 08:19 AM
Whirlpool oven removal k4thdan Electrical 3 11-23-2010 03:42 PM
