Whirlpool Duet Washer Squeak - Appliances - DIY Chatroom Home Improvement Forum
Old 04-17-2019, 04:51 PM   #1
Rewards Points: 70
We have a Whirlpool Duet Washer Model WFW94HEXW2.
About 7 years old.
It has recently developed a ‘squeak’.
The squeak sounds pretty much like a door hinge.
Here are some other facts about the situation:
1. Occurs when the tub is spinning.
2. Doesn’t seem to occur when the tub is spinning fast. Like when it is spinning the water out. Seems to occur at a more moderate speed.
3. Doesn’t happen all the time. That is, some loads will cause a squeak. Others won’t.
4. There is NO ‘grinding’ or ‘rattling’ sound.
5. I can not reproduce the sound with the unit off. I’ve tried spinning the tub by hand in both directions. Moving it as much as possible.
6. No signs of any debris in the rubber gasket at the front.
7. It does seem like there is a lot of ‘play’ in the tub when I grab it and move it around. It is very easy to move it through several inches of travel with minimal effort.
Well, thanks for any help or advice!
randyw57 is offline   Reply With Quote
Tags
duet , squeaking , whirlpool washing machine
Creaking - Whirlpool Duet Front Load Washer homerb Appliances 2 01-03-2012 10:30 PM
Whirlpool Duet Washer Fabric Softener Drain Leilam1065 Appliances 1 12-12-2011 06:49 PM
Whirlpool Duet washer front load sdaniels Appliances 3 03-13-2011 03:37 PM
Anyone have a Kenmore Elite / Whirlpool Duet washer? HVAC_NW Appliances 3 12-22-2010 08:57 PM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 01:57 PM
