What Is In My Ice ? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-27-2020, 10:52 AM   #1
Rewards Points: 1,254
what is in my ice ?
hello
when a glass of water and ice melts, there is stuff in the bottom of the glass. what could this be ? i do have a water softener on city well water. but where we used to live, chicago city water, and a different fridge, we had the same problem. so is this typical of icemakers ?
thanx
Fix'n it is offline   Reply With Quote
Old 05-27-2020, 11:02 AM   #2
Rewards Points: 1,836
Re: what is in my ice ?
How are your ice cubes made? By hand or by your fridge?
In other words, do you fill your an ice cube tray with tap water or do you have an automatic ice cube maker?
If you use an ice cube tray, do you use a water filter pitcher to fill the tray?
If an ice cube maker, does it have a filter?
More than likely, it is mineral build up in your ice cubes that settle out.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 05-27-2020, 12:51 PM   #3
the first fridge we made them by hand with pitcher filtered water. now, an automatic in the fridge. no filter. i am thinking about an inline. but i don't want to do that and have it not fix the problem.
Old 05-27-2020, 01:44 PM   #4
Rewards Points: 712
You haven't said what kind of "stuff" is in the cubes. I assume that if you run a glass of water from the tap and leave it set on the counter for a few minutes you do not see anything in it? Assuming it's only in the ice, and it's "flecks", it's most likely calcium carbonate, and I can't say for sure because I have not dealt with it myself, just have known a few others who have, but do not believe that it is harmful at all. I remember someone saying they had ended up bypassing the softener for the ice maker, but not sure I would do that as it seems like it could lead to wear on the valve. You might check your water hardness though and see if you could possibly throttle the softener back a bit. Otherwise, you could try a filter, but, as you mentioned, you might do that and not see any change.
Old 05-27-2020, 02:52 PM   #5
Rewards Points: 1,001
Sure looks like hard water.....best solution IMO would be to plumb the ice maker with the output of an RO system.
Softening the water with salt will work but you are just adding chemicals to your drinking water.
Completely clean or replace that old ice maker because the crud will continue to come out of it for a long time.
DanS26 is offline   Reply With Quote
Old 05-27-2020, 03:30 PM   #6
Rewards Points: 1,322
The inline carbon filters are only $10-$20. If you get one with push-in compression fittings already on them, it's a 5 minute install.
HotRodx10 is online now   Reply With Quote
The Following User Says Thank You to HotRodx10 For This Useful Post:
Fix'n it (06-02-2020)
Old 05-27-2020, 08:53 PM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 2,082
We get that in our ice and it is mineral accumulation. We have a softener but trace amounts still remain. As the ice evaporates in a frost free freezer, the minerals are left behind. We don't go through a lot of ice and the ice in the bottom of the tray can often be there for months (often, the wife just reaches into the tray and grabs cubes from the top rather than use the dispenser.). It hardens into a lump and only the cubes in the centre get picked up by the auger. I dump it all out every couple of months, clean it and start over.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Old 05-27-2020, 10:57 PM   #8
As others have stated, it is mineral build up. Newer fridges have a filter that does it for bother the ice and water.
Get a filter that you can cut into the supply line for the ice maker and once you clean up the ice maker, you will notice a vast improvement.
The Following User Says Thank You to ktownskier For This Useful Post:
Old 06-02-2020, 11:30 AM   #9
i'm back, been busy.
i tested water form the tap, nothing. i ran water from the water supply on the fridge, the first 1/2 glass had a little, the second full glass had none. i also melted some ice in a glass, see pic.
i got to thinking, it could be deposits that are building up in the system, because we use not much ice and no water, the system doesn't get flushed . so i have started doing that. and it may be degradation of the plastic line from the salt water. we can not change to none softened water, it tastes bad.
Old 06-02-2020, 01:01 PM   #10
Some minerals precipitate (settle out) from the water when it freezes. The effect is worse if the ice sits for a long time and the ice sublimates (evaporates directly to vapor), so there's less ice, but all of the minerals remain.
Old 06-02-2020, 03:23 PM   #11
are you saying that freezing the water makes the minerals separate easier ?
Old 06-02-2020, 07:09 PM   #12
Yes.
Why does defrosted water contain impurities when the water was perfectly clear prior to freezing?
Fix'n it (06-04-2020)
Old 06-04-2020, 11:00 AM   #13
very interesting, thanx.
so, basicly, a filter will do nothing ? loaded question i know. saying this, my softener gets out a lot of the minerals in the city well water, and actually makes it taste just like nothing. and then the little salt that is in it from the softener.
Old 06-04-2020, 02:13 PM   #14
Rewards Points: 4,220
Kryptonite is in your water, it will keep Superman at bay.
Old Thomas is offline   Reply With Quote
Old 06-05-2020, 06:59 AM   #15
well i'm in trouble then
