Water Dispenser - No Cold Water - Appliances - DIY Chatroom Home Improvement Forum
Old 04-06-2017, 04:51 PM   #1
Rewards Points: 42
Water Dispenser - no cold water
I have Primo Top-Load Water Dispenser, model 900128. Been using over a year. Few months ago, I turned off the cold in winter. Now I turned back on and it's stopping working. No cold. Only water. The hot is working fine.
Link to the model: https://www.walmart.com/ip/Primo-Top...White/16651273
hpdad is offline   Reply With Quote
Old 04-08-2017, 09:15 PM   #2
Rewards Points: 40
Re: Water Dispenser - no cold water
From Primo's website:
Q. The cold water is room temperature.
A. There is a cold water thermostat control mounted to the back of the majority of our appliances. Simply unplug the power cord of the appliance. Pull the appliance away from the wall so you have free access to the back. Do not remove anything from the appliance; simply locate the dial which resembles a gold/brass-colored flathead screw in the area of the black condenser coil grill. Use a flat screwdriver to adjust the dial clockwise to cool the water. Do Not adjust this piece more than 1⁄4 turn. Turning the control too much will cause water to freeze in the appliance’s reservoir and may lead to other issues.
gapotts is offline   Reply With Quote
Hot water from cold pipes, plumbers are stumped seabeast Plumbing 75 03-31-2015 10:52 PM
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 05:19 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
