Washing Machine Not Working After Power Outage - Appliances - DIY Chatroom Home Improvement Forum
Old 11-04-2014, 07:50 AM   #1
Rewards Points: 101
I have a Frigidaire stackable washer/dryer(model FFLG2022MW). Yesterday it was running and we had a short power outage. When the powere came back it ran for a few minutes and then stopped. The dryer still works perfectly fine.
I keep reading about resetting the washer or motor after a power outage but can't find anything specific to this model. The most common suggestion says to unplug for a few minutes then open and close the lid 6 times. My problem is the lid is stuck in the locked position.
Any ideas on resetting this model?
jte1130 is offline   Reply With Quote
Old 11-04-2014, 09:37 AM   #2
PoleCat's Avatar
Rewards Points: 1,652
If you can't easily reach the plug turn off the breaker. Then turn it back on after a minute.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-04-2014, 10:33 AM   #3
Rewards Points: 101
Thanks PoleCat. I've already unplugged and also turned the breaker off and on. There is definitely power going to it as the dryer runs. They are a stacked unit with the same plug. I've read about different internal reset mechanisms but can't find anything for this model.
Old 11-04-2014, 10:41 AM   #4
PoleCat's Avatar
The only reset is removing power that I could see in the manual.
Old 11-04-2014, 12:02 PM   #5
Rewards Points: 2,600
if killing power doesnt fix then it will be suspect that the outage caused failure of a control board. many machines today have fault code readout, but if you cant get that either then you will need your control board(s) checked by someone who can check them and/or replace the controls.
i always recommend a power surge wall-wart for electronic based items, doesnt always save the item, but helps.
you could buy new controls via online parts place, try it to see if it fixes problem, if not then return the parts, etc.
or, spend that $75 for a tech to come out to press the buttons and what-not just to tell you "yep, not working, you need new controls".
concrete_joe is offline   Reply With Quote
The Following User Says Thank You to concrete_joe For This Useful Post:
curtd (11-07-2014)
Back up generator for main panel in power outage. Greenie Electrical 44 07-29-2015 11:57 PM
Cause of slow washing machine drain? mgood777 Plumbing 9 11-29-2013 08:56 PM
Partial Power Outage - What May Have Happened? brgmgb Electrical 9 01-24-2013 05:23 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
