Washer Problem, Warm Water Output Is Not Warm - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-30-2015, 02:45 PM   #16
Rewards Points: 424
I found the model number.
I found the hot/cold shut off valves, they were right beside the washer. (In the pic, the left one is the HOT and right one is the COLD). The cold one turns, the hot one seems stuck. I tried turning it with a pair of work gloves on and still no go. Any ideas how to get it loose?
close up of hot water shut off.
ghary is offline   Reply With Quote
Old 07-30-2015, 02:52 PM   #17
Rewards Points: 424
Here are the manuals I found with the model number, I will take a quick look through them.
https://dl.dropboxusercontent.com/u/...9/L0305269.pdf
https://dl.dropboxusercontent.com/u/...9/L0401315.pdf
Old 07-30-2015, 03:30 PM   #18
Rewards Points: 137
Ok, so no automatic temp control on that model. Just need to get that valve shut off so you can remove the hot water hose. Here is a view of the screens on the inlet valve assembly. As you can see, they are tucked inside and are a little difficult to get to to clean them or you can just replace the whole thing, it only runs around $13 and these machines are easy to service.
http://www.appliancepartspros.com/wh...ap3094541.html
thefixer56 is offline   Reply With Quote
Old 07-30-2015, 04:03 PM   #19
Rewards Points: 424
Any ideas how to loosen the valve? I tried brute force and it didn't work.
Old 07-30-2015, 07:29 PM   #20
GrayHair's Avatar
Rewards Points: 1,396
Is the hot water valve fully open? If not, you can try to rock it back and forth between open and closed (hand pressure only). This can cause a slow drip, but SLIGHTLY loosen the packing nut, try the valve again, the re-tighten the nut. If it drips afterward, the stem packing will need to be replaced and at that point, I would rebuild the whole thing.
Oh. Is the piping copper or galvanized?
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 07-30-2015, 08:53 PM   #21
Rewards Points: 2,688
Soak valve with wd40, or pb blaster, let it soak for awhile then carefully work it back and forth (cw/ccw) and try to loosen it. Use a rag on the gate valve handle and hold it underneath with other hand for support. If no luck, it may have to be replaced or rebuilt. Just a suggestion.
jmon is offline   Reply With Quote
Old 07-31-2015, 09:37 AM   #22
Rewards Points: 424
I tried using a propane torch on it for a few seconds and then turning with a pair of work gloves on, still won't budge. I think I might leave it alone.
The Following User Says Thank You to ghary For This Useful Post:
jmon (07-31-2015)
Old 07-31-2015, 12:35 PM   #23
Good idea for now ghary.
It's working now, once you mess with it, it may not work anymore or leak, and then you would have to replace or rebuild it.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-09-2014 12:40 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Warm water coming from cold faucets ygillard Plumbing 2 03-02-2012 03:24 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 08:28 PM
