Washer Mystery - Appliances - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 07:49 AM   #1
the Musigician
DangerMouse's Avatar
Washer mystery
The wife found this in the bottom of the washer.
Is it part of the machine? Plastic with rubber washer.... it looks familiar....
DM
Old 06-04-2011, 08:47 AM   #2
Rewards Points: 252
Looks to me like a broken zip tie connector.
Marty1Mc is offline   Reply With Quote
Old 06-04-2011, 08:50 AM   #3
the Musigician
???? I'm afraid you lost me.
Do you have a link or pic to what you think it is?
DM
Old 06-04-2011, 09:06 AM   #4
Rewards Points: 252
I'll see if I can locate one. But, on automotive (my main background outside electronics), they use a clip- type zip tie. The bottom of the thing you posted is a clip. It fits through a hole and holds the piece in place. Then it has a zip tie molded as part of the assembly. It is used to secure cables, wires on the body of whatever. The clip is pushed through the hole, the zip tie part is wrapped around the wiring and it secures it in place.
I hope that helps. I have been searching for a link to show you, but so far no luck...
Old 06-04-2011, 09:16 AM   #5
Newbie Bill
Rewards Points: 534
For proper forensic identification, you should photograph evidence beside a small ruler.
Besides that, I got nothin.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-04-2011, 09:19 AM   #6
the Musigician
MY thought (read "worry") is that it's some part from the washer that somehow fell into the tub?
But....maybe it was something the kid found and had in his pocket?
DM
Old 06-04-2011, 09:21 AM   #7
Master Electrician
SD515's Avatar
Rewards Points: 506
Lid/upper panel retainer ?? Take a pic next to a ruler or a quarter maybe.
Kyle
Old 06-04-2011, 09:25 AM   #8
Master Electrician
SD515's Avatar
Rewards Points: 506
The rubber washer makes me think a seal, but more likely anti-vibration.
Kyle
Old 06-04-2011, 09:26 AM   #9
the Musigician
It's an inch and a quarter or so long.
DM
Old 06-04-2011, 09:31 AM   #10
the Musigician
I'm thinking more and more it was in someone's pocket and just got washed. I looked the machine over and cannot find any place it may have been attached to or fallen from.
DM
Old 06-04-2011, 10:02 AM   #11
Learning by Doing
Leah Frances's Avatar
I have a jar of these small, specific, thingies. My last one found was a small grey bushing. Every now and then I remember/find what it's for.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-04-2011, 10:04 AM   #12
the Musigician
Next time I think I'll put my glasses on before I look at something. *sheesh*
It's the push rod for the lid, with rubber bumper.
The square hole it clips into rusted out around the edges.
A bit of JBQuik and it's back in place.
I'll fill in the area around it with PL construction adhesive in a few after the JBQ sets up. That'll give it more support and help keep it from rusting out again.
Thanks for the help guys!
DM
Old 06-04-2011, 10:08 AM   #13
Master Electrician
SD515's Avatar
Rewards Points: 506
Good detective work Scooby !!
Kyle
Old 06-04-2011, 10:12 AM   #14
the Musigician
Thanks.... do I get a cookie now?
DM
Old 06-04-2011, 10:18 AM   #15
Master Electrician
SD515's Avatar
Rewards Points: 506
No... A Scooby snack !! But you have to share with Shaggy...
Kyle
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 06:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
