Trying To Repair Utility Light - Appliances - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By pwcopy
  • 1 Post By MTN REMODEL LLC
  • 4 Post By Domo
Old 12-03-2018, 11:57 AM   #1
Rewards Points: 144
Trying to repair utility light
Put a new 150W halogen lamp in this fixture and no light. Took the fixture apart and tested voltage from cord (OK). Tested the continuity of the lamp and lamp holder, and this is where it gets weird.
Lamp by itself: .003.
Lamp in lamp holder: 1 no continuity)
Lamp removed from holder, hot+neutral leads twisted together and meter probes touched to lamp contacts: .009
I'm not an electrician. Can anybody tell me why the light won't work?
Many thanks for your help, PW
pwcopy is offline   Reply With Quote
Old 12-03-2018, 04:00 PM   #2
Rewards Points: 18
Re: Trying to repair utility light
Probably a bad bulb, especially if you touched it with bare fingers.
Seattle2k0 is offline   Reply With Quote
The Following User Says Thank You to Seattle2k0 For This Useful Post:
pwcopy (12-04-2018)
Old 12-03-2018, 04:10 PM   #3
Rewards Points: 2,680
Sometimes depending on type of fixture, the tab in the light socket itself gets push down really far and doesn't make contact with the bulb anymore. Try pulling it up with a flat tip screwdriver, with power off of course.
If still no good, then maybe something is wrong with the internal wiring of the socket or the socket itself is bad. If that's the case, better to just replace the fixture.
As mention, use a sock when changing the halogen bulb. They don't like fingerprints. Just a suggestion.
jmon is offline   Reply With Quote
Old 12-04-2018, 10:23 AM   #4
Rewards Points: 144
I'll give pulling up the tabs. I always use a kleenex or rag when changing halogen lamps. Many thanks for the help.
jmon likes this.
Old 12-04-2018, 10:28 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 724
JMON...Thanks... never thought of a sock... has to be easier than paper towels.... especially when you're atop the ladder
jmon likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 12-04-2018, 09:58 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 924
Probably not related, but I have found that some moulded rubber lamp sockets don't play nice with some bulbs. When I was temporarily wiring a barn, I used some pigtail sockets and found that certain incandescent bulbs wouldn't screw in far enough to make contact. Different manufacturers have slightly different shapes to the bulb part. Drove me nuts.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 12-06-2018, 01:50 AM   #7
Contractor/Engineer
Rewards Points: 1,170
I tried using a sock but fell off the ladder when I lifted my foot up to the light...
Domo is offline   Reply With Quote
Old 12-19-2018, 06:35 AM   #8
Rewards Points: 32
Maybe because of the bulb or the socket itself.
johndale is offline   Reply With Quote
Old 12-21-2018, 02:56 PM   #9
Contractor/Engineer
Touching it simply transfers oil that can then make the glass crack when the halogen bulb get's hot.
Just touching the bulb does not make it go bad immediately.
Most likely, one of the wires is crimped to a lug that is riveted to a contact. The rivet has become loose/corroded due to the thermal expansions and contraction. I've sometimes used silver solder and made that mechanical joint (the rivet to lug) permanent. Silver solder takes the heat better than standard solder. YMMV.
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 03:15 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
