Top Loading Washer Max 25.5" Depth - Appliances - DIY Chatroom Home Improvement Forum
Old 01-22-2019, 12:48 PM   #1
Rewards Points: 2
Top Loading Washer max 25.5" depth
I'm in need of a new washer and I have a tight space and can only accommodate a washer that is 25.5" deep. My prresent washer is 3.5 cu ft and I don't want to go any smaller capacity. I'd welcome any suggestions.
cinderella is offline   Reply With Quote
Old 01-22-2019, 12:55 PM   #2
retired framer
Rewards Points: 4,326
Re: Top Loading Washer max 25.5" depth
apartment sized.
https://www.bestbuy.ca/en-ca/product...B&gclsrc=aw.ds
Old 01-22-2019, 01:40 PM   #3
Rewards Points: 384
error
Nik333 is online now   Reply With Quote
Old 01-22-2019, 02:24 PM   #4
Oso954's Avatar
Rewards Points: 632
I think you will probably have to give on one requirement or the other.
You either need to fit in the 25.5 inch space, which will be some thing under 3cf, or you want the 3.5 which is going to be roughly 27x27.
Here’s a 2.8 Cu ft example
https://www.homedepot.com/p/GE-2-8-c...SMWW/305143814
Oso954 is online now   Reply With Quote
Occasionally, there's water under our front loading washer raggedsweater Appliances 5 06-15-2017 01:28 PM
Vibration In High Speed Spin Mode Davy49 Appliances 7 12-30-2014 10:47 AM
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 09:23 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 02:57 PM
