Thermidor Refrig Random Beeping - Appliances - DIY Chatroom Home Improvement Forum
Old 10-27-2016, 09:00 AM   #1
JPM
Bill Traver
Rewards Points: 137
I am going nuts with random beep from my Thermidor T24IR70NSP/03 refrigerator. IT will stop for several minutes then start for many more. Does not seem to be linked up with fan.
Have tried power off/on and adding tape to the door switch ... neither worked. Looked through manual and online but have not found anything ... any sort of help on this would be tremendous.
I do have the display showing FILTER but this is a side by side unit with no water.
Again, thanks to all on the forum.
JPM is offline   Reply With Quote
Old 10-27-2016, 11:42 AM   #2
Pro DIYer
CountryB's Avatar
Rewards Points: 102
Re: Thermidor Refrig Random Beeping
Sounds like you found the problem. The "filter" needs to be changed. You said you don't have water - but you probably have an ice maker so the filter is there. If you don't want to replace the filter, there is going to be a "filter needs changing" reset method (like holding the button next to the "change filter display" for 4 seconds). The manual will say how to reset the filter change warning.
CountryB is offline   Reply With Quote
Old 10-27-2016, 11:52 AM   #3
JPM
Bill Traver
Rewards Points: 137
I do have an ice maker but the freezer is a completely separate physical unit.
They are next to each other (built in) ... I do not think that they communicate via wiring to each other as the freezer side is not beeping.
Not sure if this feedback helps.
Funny how frustrating something like this can be.
Smoke alarms won't stop beeping Whyjune1st Appliances 3 05-27-2016 08:09 PM
Random stud placement in basement going south Building & Construction 9 10-21-2015 02:21 PM
First Co. 36RCW5-HP blower stopping at random times cout HVAC 2 07-06-2011 05:51 PM
Random Orbital Sander Suggestions (<$100) hyunelan2 Tools 11 03-28-2011 08:49 AM
Ridgid Random Orbit Sander jamiedolan Tools 2 03-17-2009 03:23 AM
