Sump Inlet - When Do You Replace? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-26-2016, 06:50 AM   #1
Rewards Points: 259
Sump inlet - when do you replace?
I have a GE Triton XL dishwasher. I was cleaning the sump filter basket last night and also inspected and cleaned the sump inlet. The sump inlet (which I presume is rubber, feels like it) looks like old rubber - yellow to brown tinge in some areas, sticky/tacky feel on the vertical cylindrical tube.
Does being in an old rubber state warrant replacement? Or do sump inlets survive and function as is?
When I did a search, I read that people replaced their sump inlets because their dishwashers leaked - sump inlets had holes because they were usually eaten by rats/mice. Some had sump inlets that disintegrated/crumbled and clogged spray arms.
We don't have rats/mice but I'm wondering if my sump inlet will eventually go the way of disintegrating by itself. I'm wondering if I should be doing a preemptive replacement or just leave it alone. I'm not very keen on pulling the DW out and tipping it on its side to access the bottom (because I'm a puny girl and so I'm not sure if I can lift/tilt it upright once it's down).
Druidia is online now   Reply With Quote
Sump pit filling faster when showers running... MoreCowbell70 Plumbing 37 07-02-2016 06:26 PM
Sump water level pnorman55 Plumbing 18 03-21-2016 01:16 PM
The great sump debate.. above or below inlet mikegina Plumbing 2 02-01-2013 04:54 PM
Sump pit oddities? memmo Plumbing 0 12-06-2012 06:36 AM
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 12:09 PM
