Stovetop - Igniters Not Firing - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By wooleybooger
Old 02-22-2019, 08:53 PM   #1
Rewards Points: 6
Question
Stovetop - igniters not firing
I have a Hotpoint, Model RGB805PEH1WH. last week all the burner igniters stopped sparking at once. What is the most likely cause? Am I right to think that it isn't a spark igniter switch? If the first one failed, would it stop them all from working? Or is it most likely the spark module?
Thanks Tom
GibbyDIY is offline   Reply With Quote
Old 02-22-2019, 09:16 PM   #2
Rewards Points: 534
Re: Stovetop - igniters not firing
Check for power first. A lot of the switches are sold four switches with everything wired together with a wire harness. So itís possible a broken wire in harness (it wouldnít be one switch bad if they all went out). You can check if the switches are putting power to the module. If it has power but itís not putting out itís the module
BayouRunner is offline   Reply With Quote
Old 02-23-2019, 07:39 AM   #3
Rewards Points: 7,261
If you have power at the outlet it is most likely a bad spark unit. It is a simple plug and play replacement. This is what one looks like: https://www.mccombssupply.com/gas-ra...3096-ps235158/
Shop around $30-50 is normal pricing.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-28-2019, 10:19 AM   #4
wooleybooger's Avatar
Rewards Points: 764
$1 ea. at the Dollar stores. $30/$50 will buy a lot of them.
bob22 likes this.
wooleybooger is offline   Reply With Quote
Old 03-01-2019, 07:57 AM   #5
Rewards Points: 536
LOL You must be the one who drives past my house with a duct tape drivers window....
tmittelstaedt is offline   Reply With Quote
Old 03-01-2019, 09:03 AM   #6
Rewards Points: 764
Not me. Duct tape is too expensive and you can't see through it. I use clear trash bags. I drive safely.
There's no such thing as free lunch, too much horsepower or spare change~anonymous
There is no such thing as free shipping either~Wooleybooger
Old 03-05-2019, 03:20 PM   #7
Rewards Points: 480
When you turn the knob to "light" do you still get the clicks, even if the burner doesn't ignite? Check the igniter and see if there's any food debris blocking gas flow to it.
huesmann is offline   Reply With Quote
Boiler not firing Joe F HVAC 1 11-18-2017 01:40 PM
Gas furnace not firing ericzy01 HVAC 1 02-21-2013 07:50 PM
firing stripes kebean Drywall & Plaster 2 04-24-2011 12:11 PM
Riding Lawnmower, Wrong Firing chainsawmatt Landscaping & Lawn Care 8 02-20-2011 08:49 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
