Samsung Dryer Not Starting - Appliances - DIY Chatroom Home Improvement Forum
Old 04-03-2017, 10:33 AM   #1
Rewards Points: 94
Samsung Dryer Not starting
We have a Samsung Dryer, model DV45H7000AW that is 3 years old. When I press the Start button there is a humming sound and the cycle won't start. I will press the power button to turn dryer off and then turn power on again, and press the Start button and the dryer will start the cycle. There is no consistency as to when this will happen. Almost as if there's a short? I'm afraid if I call a Service tech out; the dryer will start right up for him and I'll have wasted a Service call. Please advise.
jnstevens is offline   Reply With Quote
Old 04-03-2017, 02:46 PM   #2
Rewards Points: 534
Re: Samsung Dryer Not starting
Most likely something stuck in the blower wheel, sock, dryer sheet, rag. Or a bad motor.
BayouRunner is offline   Reply With Quote
Old 04-03-2017, 03:23 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 17,378
It's pretty easy to pull the fronts off.
As Bayo said...chances are it sucked up a sock.
Any chance you ran it without the lint filter?
ddawg16 is online now   Reply With Quote
Old 04-03-2017, 03:26 PM   #4
Rewards Points: 94
I have always ran it with the lint filter. I will try to take the front off and check.
Old 04-12-2017, 08:18 AM   #5
Rewards Points: 94
Ok, so we had a Service tech come out and look at the Dryer and he said it needs a new motor. He wants $481 to replace the motor. The tech did say that my model has replaced the motor in this unit with an upgraded motor. I just can't believe after less than 3 years the dryer needs a new motor. I'm going to write a letter to Samsung but not sure it will do much good. Not going to buy another Samsung. What is the most reliable brand out there?
Old 04-12-2017, 12:51 PM   #6
JOATMON
ddawg16's Avatar
Buy a new motor off the internet....I replace one once...it was about $70 and took all of 1hr to replace
Old 04-12-2017, 03:03 PM   #7
Rewards Points: 94
Ok, now I have found a new motor OEM (Original Equipment Manufacturer) on Amazon, New for $107.79. Local guy will install a new motor that he'll supply for $171 and he said it's FSP (Factory Certification Parts). Does it make a difference in OEM and FSP? Or is the local guy just trying to get more money for the part?
