To Replace Or Not Replace - Appliances - DIY Chatroom Home Improvement Forum
Old 10-20-2014, 07:32 PM   #1
GC/Master Plumber/Mech
Rewards Points: 590
To replace or not replace
Today I had a fridge diagnosed by another company to have a bad compressor. I found the start control out. Replaced and the compressor ran but still not cooling. Put gauge on and the system was empty. Put nitrogen to it and found an evap coil leaking. The defrost heater was right next to the coil causing a leak
The coil is not that much to replace on a 2 yr old fridge but, I was told to also replace the compressor.
Should I replace the compressor or pull a long deep vacuum?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-21-2014, 04:22 PM   #2
Bob Sanders's Avatar
Rewards Points: 2,536
If the compressor is actually working and you have tested/verified, then go for the deep vac, save your client some money and come out smelling like roses. He call you FIRST the next time.
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
Plumber101 (10-21-2014)
Replace hot water tank BrunenG Plumbing 2 10-19-2014 09:27 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 09:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
