Removal Of Maytag Fridge Meat/cheese Drawer - Appliances - DIY Chatroom Home Improvement Forum
Old 11-08-2019, 11:08 AM   #1
Rewards Points: 38
Removal of Maytag fridge meat/cheese drawer
I have a Maytag model MTB2156GEW, older but working well. Sadly, the first problem (that I recall) is damage to clear plastic suspension channels for the meat/cheese drawer, which hangs off a shelf. In the link below, the shelf is item #2, the channels #4. To repair of replace the channels... how do I get them out? Each is slotted into a trio of z-shaped cuts into the shelf's supports. At first glance, pushing the channels straight back away from me should work - but they won't budge, the "z-shaped" aspect of the cuts seem to preclude that.
PLUS, how do I remove the shelf #2 from the machine? It clips into a slotted vertical standard similar to household shelving but, again, stuck. I see two blue plastic "triggers" at the connection point, pushing them in or trying to press them side to side has no effect.
https://www.partselect.com/ModelSect...erator&Mark=11
Seabrook1983$ is offline   Reply With Quote
Old Yesterday, 08:07 AM   #2
Rewards Points: 382
Re: Removal of Maytag fridge meat/cheese drawer
Photos of actual items?
Not familiar with that model, but can you remove the "triggers"—like pull them out?
huesmann is offline   Reply With Quote
Old Yesterday, 09:07 AM   #3
Mystriss's Avatar
Rewards Points: 3,458
I don't have a maytag but I have to unscrew the tracks to get some of the drawers in my viking out >.<
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is online now   Reply With Quote
Old Today, 01:00 PM   #4
Rewards Points: 2,434
For my Maytag, I take the glass out and then tilt the standards/arms up and back; then they come out.
bob22 is online now   Reply With Quote
