Pump Recommendations To Flush Electric Tankless Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 04-15-2019, 09:40 AM   #1
Rewards Points: 221
Pump recommendations to flush electric tankless heater
I searched for this and came across a thread from 2018. I attempted to reply, but it's too old.
That thread suggested this pump, and it appears to be a good choice.
https://www.amazon.com/gp/product/B000X05G1A/
1. Is it possible to get a pump that is too powerful and can damage the heater?
2. Is it a good idea to turn off the breaker to the heater while the rinse is happening? There's no need or point in heating up the vinegar, right? Plus, it would save some $ on the electric bill.
3. The hose size should be standard, right? The specs for my model show:
Pipe fittings: 1/2 Compression. So I should get 1/2" female and a X" to match the pump fitting. That pump shows 1.25" fitting but includes a 3/4 hose adapter.
NABRIL is offline   Reply With Quote
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
Electric Hot water heater, tank or tankless OR multi tankless? blakesgst Appliances 6 10-23-2015 11:34 AM
tankless water heater flush - vinegar discolored autx790 Plumbing 3 10-10-2013 06:32 AM
Wiring for an electric tankless water heater madleader Electrical 40 07-26-2012 10:29 PM
electric tankless water heater over oil burner fishman1 HVAC 5 02-27-2012 06:54 PM
