No Longer Able To Turn Off Fan Or Light For Vent Hood - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 01-06-2019, 03:12 PM   #1
Rewards Points: 4
No longer able to turn off fan or light for vent hood
Hello. I have an issue that I would very much appreciate some help with. I overturned the knobs for both the fan and the light of my vent hood and they stayed on until they died. The problem is that the vent hood I have is rather old and I'm not sure if it's possible to repair myself or if I will likely have to just get a new one. I have turned off the power to it, but it does not seem to be an easy task to replace the knobs and the fan motor. I know very little of electrical except to turn it off from the breaker box if I am to work on it, which I have. I have attached images of the inside of the panel with the wires and where the knobs are. It doesn't seem possible to unscrew the fan and light parts from the outside or the inside. It's a Nutone Scoville Mercury vent hood. The light still works, as I put in a new bulb and it comes on fine. But I want to be able to turn it off and not let it stay on until it burns out. Not sure how I let the knob get overturned, but that seems to be why I can no longer turn the light or fan off.
No longer able to turn off fan or light for vent hood-imag0110.jpg   No longer able to turn off fan or light for vent hood-imag0111.jpg
bubbagumptwin is offline   Reply With Quote
Old 01-06-2019, 03:15 PM   #2
Rewards Points: 4
Re: No longer able to turn off fan or light for vent hood
The black round thing in the top picture? That's the socket for the light bulb. In the bottom picture if you look in the far back part of the panel with 2 "sockets" - they are the knob selector switch parts (left is light and right is the fan).
Old 01-06-2019, 06:19 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 680
How long did that take?? If the motor has died, it appears you have a switch problem and a replacement hood is in order. Luckily they aren't that expensive. I'd change it out.
Dave Sal likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-10-2019, 10:32 AM   #4
Rewards Points: 2,820
There are lots of things wrong with it now. This suggests you should replace it rather than repair it.
1. Caked up with grease.
2. Fan motor has failed.
3. Switch has failed.
4. (maybe more?)
Although I myself might consider at least briefly the idea of repairing it, having to clean it quickly turns my opinion towards replacing it.
Old 01-10-2019, 02:27 PM   #5
Rewards Points: 1,700
Unless you're flat broke, replace it. Under $50 at Big Orange.
huesmann is offline   Reply With Quote
Do I need to prime and paint after this? cue8chalk Painting 28 06-12-2015 06:28 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
light switch won't turn off light nredburn Electrical 4 11-20-2012 08:45 PM
how to turn ceiling light into a fan w/ ceiling light MLMIB Electrical 4 06-06-2011 09:04 AM
new light fixture won't turn off. iceracer Electrical 6 07-14-2010 10:22 PM
