Need Dryer Vent Ideas - Appliances - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 08-19-2018, 10:42 AM   #31
Rewards Points: 2,074
Re: Need Dryer Vent Ideas
This has become way to complicated. You had the answer yourself. Remove the pipe and run a 90 deg ell straight up the garage wall make a left turn straight out the wall where the stand is. just make sure you don't use screws use metal tape and pipe hangers. So all you need is two 90 deg ells and a couple lengths of pipe. When you install the pipe make sure you follow the direction of flow with the joints so lint don't catch. It's a very simple job. you don't need stacked units. KISS principal. You should never have a problem. Maybe once every year or two open the ell at the bottom of the dryer and vacuum out. Good luck.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 08-19-2018, 10:45 AM   #32
Originally Posted by LarryJ-nova View Post
Not quite understanding where you're suggesting it terminate, but I like your thinking. Along those same lines, how about stay inside the garage, go over the door, turn the corner and exit out high on the left wall. Box it in. Too many turns?
" that's it you only have two turns. One up the wall and one over and out."
Old 08-19-2018, 10:47 AM   #33
Got to get rid of them shelves and other stuff so you have a straight line up the wall over and out.
Dryer vent location close to DWV vent WillK General DIY Discussions 4 10-05-2015 12:09 PM
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Dryer Vent type? cbzdel General DIY Discussions 6 06-08-2010 09:17 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
