Microwave Sparks - Appliances - DIY Chatroom Home Improvement Forum
Like Tree11Likes
Unread 05-06-2019, 11:49 AM   #1
Licensed Pro. Engineer
Rewards Points: 460
Microwave Sparks
I have a GE Profile Advantium 120 microwave in my home. It's well taken care of, so I wouldn't expect our newest problem to be a result of neglect or abuse. However, it started sparking recently while in use. It's intermittent. Someone will probably say, "you had metal in there." Nope. The item I heated last night was a plastic bottle full of water, and I had done this a thousand times in the past, same bottle, with no issues. What are some tips folks can share about what might be causing the issue?
Thanks in advance!
M Ridzon
m_ridzon is offline   Reply With Quote
Unread 05-06-2019, 12:21 PM   #2
Rewards Points: 1,836
Re: Microwave Sparks
I found a video that may help. As your user name implies, lincensed pro engineer, I'm sure you can figure something out. If it's not under warantee, I would just buy a new microwave - but that's me. Just my thoughts. Hope you can get it fixed.
Nealtw likes this.
jmon is offline   Reply With Quote
Unread 05-06-2019, 02:29 PM   #3
Rewards Points: 460
Thanks! That was helpful. I saw something else on Google talking about a faulty wave guide cover. So I'm going to check that, for sure.
Yup, I'll figure something out, but coming to forums always helps, since I'm not omniscient.
Tossing it out is not my first option. This is a pretty fancy microwave with advanced "oven-type" features, and it is part of a stove/micro set. So I'm going to try and salvage it, within reason of course.
Thanks again!
jmon and Nealtw like this.
Unread 05-06-2019, 06:35 PM   #4
rooster4321's Avatar
Rewards Points: 4
the video tells you about a piece you can buy for $5 or usually more than that but if you take it out you can clean it maybe with some very fine sandpaper I have done it and it works
Sent from my KYOCERA-E6560 using Tapatalk
Dave Sal and m_ridzon like this.
rooster4321 is offline   Reply With Quote
Unread 05-06-2019, 06:54 PM   #5
Rewards Points: 472
Jmon nailed it on the wave guide. Although good luck with buying a part from ge for $5. Itís a pretty common occurrence
BayouRunner is online now   Reply With Quote
Unread 05-06-2019, 06:59 PM   #6
Dave Sal's Avatar
Rewards Points: 710
I had the same problem last year and simply removing the waveguide, cleaning it on both sides, solved the problem. I found a replacement on RepairClinic.com but didn't need to order it as cleaning it worked.
m_ridzon likes this.
Dave Sal is offline   Reply With Quote
Unread 05-07-2019, 07:21 AM   #7
Rewards Points: 460
Can someone explain the purpose of the wave guide cover? It looks like nothing more than a flimsy piece of cardboard. And how can it cause a lightning storm in the microwave, merely from splattered food upon it?
Unread 05-07-2019, 06:58 PM   #8
adam
Rewards Points: 116
If you read the link below, the cover's job protects the electronics inside the microwave. Please be careful and I would avoid using it until it's fixed.
https://www.hunker.com/13407957/can-...aveguide-cover
adamz is offline   Reply With Quote
Unread 05-07-2019, 07:04 PM   #9
Rewards Points: 460
Thank you, I too had previously found and read that article. I'm no microwave expert, so maybe my ignorance is bliss, but it doesn't really say how or why a flimsy cardboard cover is an integral part of the machine, other than to cover internals. Nor does it say how food splatter on it leads to poor performance.
Nealtw likes this.
Unread 05-07-2019, 07:22 PM   #10
retired framer
Rewards Points: 11,714
It is not regular cardboard.
What should I do ?If there are any issues with your waveguide cover it should be replaced. When new the mica sheet is rigid and firm. Over a period of time it absorbs moisture and gets food splatters on it. It then becomes soft and flexible. The cover can be replaced either with a suitable replacement made by the manufacturer of the microwave or if the old cover is in good enough shape to be used as a template, blank sheets of mica can be purchased and cut to fit.
waveguide cover material - mica sheets
We often replace waveguide covers in our workshop. We are also asked to supply them directly. They are available mail order via our website ready made for some of the leading manufacturers or as blank sheets to make your own.
https://microwaveexpert.wordpress.co...veguide-cover/
Dave Sal likes this.
Do not use flat bottom gables with scissor trusses.
Unread 05-08-2019, 07:24 AM   #11
Rewards Points: 460
So what does the cover do, other than protecting against splatter, because I could get a piece of cardboard to do that. But it seems "mica" is the required material, for some unknown reason.
Unread 05-08-2019, 07:29 AM   #12
retired framer
I likely spreads the pattern out so you don't have one hot spot.
Unread 05-08-2019, 07:59 AM   #13
Rewards Points: 460
Okay, so now this thread is getting more insightful about what is actually going on. Thanks for this information.
Nealtw likes this.
Unread 05-12-2019, 07:48 AM   #14
Rewards Points: 460
Update & looking for more insight:
I cleaned the wave guide cover with a wet wash rag (first image below).
Sparks continue though. My wife observed it this morning for 90 seconds while microwaving food. She said the sparking occurs at the top (blue circled area in the second image below). That area is part of the advanced "oven" feature available in this appliance. To my knowledge, it does nothing while operating as a traditional microwave, so I'm not sure why sparks might exist there. There is food grime behind the mesh though, on the oven coils. Does anybody know if that might be part of the problem? Any insight?
Unread 05-12-2019, 12:18 PM   #15
Rewards Points: 472
Microwave Sparks
Replace your waveguide. Itís bad. Donít use your microwave until you do. You can ruin your magnetron
New Microwave Not Heating Intermittently wvphysics Appliances 3 05-30-2017 01:30 PM
Remove Whirlpool Over Stove Microwave HandyHerman General DIY Discussions 3 02-15-2015 01:04 AM
Replacing old hood with over-the-range microwave Nathan0115 Electrical 21 07-27-2012 03:37 PM
Replacing a OTR Microwave that Vents Outside lydiainflorida Appliances 1 03-29-2012 02:03 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 10:30 PM
