Maytag Washer Won't Start - Appliances - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By SPS-1
Old 01-01-2019, 12:20 PM   #1
Rewards Points: 9,404
Maytag Centennial Model MVWC300VW1, SN C02326563
Has round rotate/push dial for cycle select and start/stop. It won't start on any cycle. However, if I rotate to the rinse or spin portion and push the knob, it will run those portions.
Can it be anything other than need a new timer control assembly? I looked a little online -- those things not cheap -- I likely would sooner buy a new washer than put any significant money into fixing an old one.
SPS-1 is online now   Reply With Quote
Old 01-01-2019, 12:34 PM   #2
Rewards Points: 2,688
Re: Maytag Washer Won't Start
I agree with you sps, sounds like the timer. I don't know of any way to hack a quick fix. perhaps someone else will know.
https://rdt.prod.repairclinic.com/Re...c300vw1http://
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
SPS-1 (01-01-2019)
Old 01-02-2019, 08:04 AM   #3
Big Dog
Drachenfire's Avatar
Rewards Points: 4,386
A timer for your washer can be sourced at RepairClinic.com for $114. The part number is, RepairClinic Item #1481442 | Whirlpool OEM Part #WPW10175557.
Skill level to replace is 2 out of 5 (with 5 being most difficult) and 15-30 minutes to complete.
Good luck
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 01-02-2019, 02:40 PM   #4
Just that a new timer is worth as much as the current value of the whole washer. So I pulled the timer, opened it up, took a file to clean up the contacts, put it all back together ---- works like a charm.
bob22 and jmon like this.
Old 01-02-2019, 03:11 PM   #5
Rewards Points: 957
You are a true DIY'er......congrats on the repair.
DanS26 is offline   Reply With Quote
Old 01-02-2019, 03:25 PM   #6
Big Dog
Nice job.
Just an FYI, $114 would have been a cheap fix.
I recently bought a new Maytag washer. This was a basic washer with a capacity of 4.7 cu ft. It set me back over $600 on sale.
Maytag Frontload Washer hot water won't stop running bmatusicky Appliances 6 06-21-2015 08:16 PM
GE Washer won't start jberrier Appliances 2 01-04-2012 07:54 PM
Maytag Washer LAT2300AAE Lee C Appliances 2 12-20-2011 06:30 AM
Maytag Front Load Washer Won't Spin Dry KarenG Appliances 1 12-01-2011 08:41 PM
washer will not start badnews582008 Appliances 1 05-25-2009 12:46 PM
