Maytag MFI2569 Fridge Dead?! - Appliances - DIY Chatroom Home Improvement Forum
Old 04-11-2019, 02:20 PM   #1
Rewards Points: 1,052
Maytag MFI2569 Fridge dead?!
Came back from vacation and found the 9 year old fridge stone dead and everything melted.
Yesterday morning the display flashed occasionally. As the day went on, it flashed more often and occasionally stayed on a couple seconds. When it stayed on longer, the compressor would go for a couple seconds. Then longer, and now it has been working normally for 24 hours.
Any idea what is going on, and if it can be saved?
My wife doesn't care; she points out the the door seals are falling apart and something else is likely to break any day. She just wants a new one, with fingerprint proof stainless.
Toller is offline   Reply With Quote
Old 04-11-2019, 03:26 PM   #2
Rewards Points: 18
Re: Maytag MFI2569 Fridge dead?!
Just a thought, but did you pull the refrigerator out, or look under it. From what you describe, it could be that a piece of paper or a toy, etc. could beasily under the refrigerator, and preventing the compressor fan from spinning.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 04-11-2019, 04:07 PM   #3
No, I didn't pull it out; I hate messing with the copper water feed.
But that wouldn't cause the display to be out, and then flashing; would it?. I assumed that the problem was in the electronics rather than the mechanics; but I don't know much about refrigerators.
Old 04-11-2019, 05:04 PM   #4
Rewards Points: 18
I don't know much either. You can still get a look by opening the door, pulling off the toe kick, and using a flashlight, look for some obstruction.
It seems to me that if the compressor had gone bad, it wouldn't be working now.
You could also try going to repairclinic.com. Enter your model number, and they have videos on how to diagnose.
Old 07-18-2019, 09:11 AM   #5
Rewards Points: 202
I think you can change the old fridge.
MasterPipe is offline   Reply With Quote
Old 09-12-2019, 12:50 PM   #6
Rewards Points: 24
The solution looks straight forward to me.
If the wife wants it changed, work or doesn't work, CHANGE IT!
Would you rather change the wife?
abekrausz is offline   Reply With Quote
Old 09-12-2019, 08:01 PM   #7
Rewards Points: 386
could be a controls problem - would need to see a schematic to tell you were to start.
compressors rarely fail.
if the compressor is good and the unit isn't leaking refrigerant, fix it.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Maytag fridge leaking water on floor r0ckstarr Appliances 2 11-01-2015 05:19 PM
Icing in Viking fridge? Solaritu Appliances 1 09-15-2015 10:52 AM
kenmore fridge won't cool str0sey Appliances 0 08-29-2011 03:52 PM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Fridge Diagnosed as "Unrepairable" Old Lady Appliances 9 06-28-2011 07:08 AM
