Lubrication For Toaster Oven - Appliances - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By Windows on Wash
  • 3 Post By NABRIL
Old 06-09-2019, 11:07 AM   #1
Rewards Points: 297
Lubrication for toaster oven
The door to my toaster oven makes a loud and annoying noise.
What can I use to lubricate that tension arm on the left side ? Wd40? Silicone or aluminum spray? It hasLubrication for toaster oven-15600927708428571492760977194221_1560092797840.jpg to withstand heat, obviously.
NABRIL is offline   Reply With Quote
Old 06-09-2019, 11:10 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,616
Re: Lubrication for toaster oven
Wouldn't use anything that is VOC generating.
Might be better to just dab some oil oil or coconut oil on it.
Dave Sal and Nik333 like this.
Old 06-09-2019, 11:26 AM   #3
Rewards Points: 297
Originally Posted by Windows on Wash View Post
Wouldn't use anything that is VOC generating. Might be better to just dab some oil oil or coconut oil on it.
Good point and thank you. I used a drop or 2 of olive oil and straightened out that arm lever, and it no longer sounds like a metal grinder... Again, thanks.
Dave Sal, Nik333 and Nealtw like this.
Old 06-09-2019, 11:39 AM   #4
JUSTA MEMBER
Rewards Points: 306
Good that you have made a repair to shut it up.
That probably was the problem, those are weak and bend too often.
I was going to suggest a drop of a Graphite Lubricant, sold to lube locks with, it won't burn, is fairly safe to ingest if by accident it gets to the cooking surfaces, but tidiness in all things is a better practice.
ED
de-nagorg is offline   Reply With Quote
