Locate Make/model Of The Microwave? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-27-2014, 10:36 PM   #1
Rewards Points: 578
Locate make/model of the microwave?
I recently bought a condo. When I opened the microwave (above the stove), I found the coupler broken (see photo).
In order to order the right type of coupler, I'll need to identify the part #, or the make/model of the microwave. FYI, it's a large stainless steel GE microwave.
Please advise where to locate the part #, or the make/model of the microwave.
Locate make/model of the microwave?-brokenmicrowavecoupler.jpg
HomeLearner is offline   Reply With Quote
Old 10-27-2014, 10:41 PM   #2
Rewards Points: 2,690
They hide them all over the place. Try looking inside of door, around back etc. See pic.
jmon is offline   Reply With Quote
Old 10-27-2014, 10:50 PM   #3
Rewards Points: 578
Thanks! I see model and serial # at door jamb.
Locate make/model of the microwave?-ge_microwavemodel-.jpg   Locate make/model of the microwave?-ge_microwavemodel-2.jpg
Old 10-27-2014, 11:00 PM   #4
Rewards Points: 578
I went to PartSelect.com web-site and searched by the model #, "GE JVM7195SF1SS". The search result showed at http://www.partselect.com/ModelSecti...E&Type=&Mark=3
From there, I found the coupler Part Number: PS2369898. It seems that it costs $50.20. Is this the correct part that I should order?
I had to drop the serial # in my search, because I wouldn't be able to find anything with both the model # and the serial #.
Old 10-27-2014, 11:14 PM   #5
Rewards Points: 578
According to web-site, http://www.appliancepartspros.com/ge...ap4484089.html, "Part Number WB06X10815 (AP4484089) replaces 1555859, AH2369898, EA2369898, PS2369898".
When I do a search by WB06X10815, I get much cheaper couplers. See http://www.ebay.com/sch/i.html?LH_FS...rowave+Coupler
Hope they are the same quality!
Old 10-28-2014, 09:54 AM   #6
Same at repairclinic.com Can't believe they want 52 dollars plus shipping for a piece of plastic.
The cheaper ones you posted look like they would work. Hard to tell by a picture. Looks good online, then when you get it, it doesn't quite fit right. I know what you mean - been there, done that. Then you wasted 10 dollars plus shipping.
Another thought; Do you have a local appliance store nearby? Take the part with you, you may get lucky. I've lucked out doing this before.
Replacing a OTR Microwave that Vents Outside lydiainflorida Appliances 1 03-29-2012 03:03 PM
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 06:46 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
