KitchenAid Ice Maker Not Working - Appliances - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By SPS-1
  • 1 Post By Druidia
Old 09-13-2019, 03:01 AM   #1
Rewards Points: 154
I have a KitchenAid refrigerator, model #KBFS20EVMS. The ice maker has stopped making ice. I have checked the supply line and it's not bent or kinked. I still get water from the water dispenser. The wire shutoff on the ice maker is in the down(on) position. Where do I go from here to start troubleshooting it and repair it? Thanks!
mrlabradog is offline   Reply With Quote
Old 09-13-2019, 04:34 AM   #2
retired framer
Rewards Points: 5,826
Re: KitchenAid Ice Maker Not Working
Here are some basic stuff to look at.
https://www.bing.com/videos/search?q...2&&FORM=VRDGAR
mrlabradog likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 09-21-2019, 04:38 AM   #3
Rewards Points: 58
I have a kitchen aid model # kfxs25ryms2 in getting water at the dispenser but nothing at the ice maker. I’m pondering if it the water valve
barnettnce is offline   Reply With Quote
Old 09-21-2019, 09:31 AM   #4
Rewards Points: 9,342
You will have separate solenoids for the ice make and the water dispenser. Fair chance the solenoid is bad.
When my icemaker stopped working, I put a small piece of paper on top of the ice mechanism in the freezer. The next morning it had fallen down to the bucket. Tried it again the next day and same result. So I concluded the icemaker was going through the motions, just that it was not getting water.
Nealtw likes this.
SPS-1 is online now   Reply With Quote
Old 10-02-2019, 03:11 AM   #5
Rewards Points: 154
Just as a follow-up to this post; I posted this on a Friday and did not have time to attempt any repairs on the ice maker over the weekend. In the 10 days just before it failed, two things happened. We had a hurricane (Dorian) and lost power for a very short amount of time and I also changed the refrigerator's water filter. I'm not sure if either of these issues had anything to do with the problem but by Monday the ice maker produced several small, discolored ice cubes that looked like they had a bit of dirt in them. Once I emptied those out and washed the tray that collects the cubes, it started to gradually increase production and has ran like a champ ever since. I'm wondering if maybe the old filter released dirt into the line when I changed it but I don't know.
Old 10-02-2019, 05:09 AM   #6
Rewards Points: 257
You should also clean the ice maker mold.
Druidia is offline   Reply With Quote
