Kitchen Hoods - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 04-23-2017, 06:53 PM   #1
Rewards Points: 181
Kitchen Hoods
Dear experts,
We are preparing for our kitchen renovation, and need to choose a hood. I wonder if we need one with an exhaust pipe to move the fumes out of the kitchen, or a hood with filter without any exhaust pipe is enough? Please advise.
Thanks,
Dmitriy
dpreznik is offline   Reply With Quote
Old 04-23-2017, 07:06 PM   #2
Rewards Points: 7,700
Re: Kitchen Hoods
In most cases an exhaust to the outside is best. If you will be using gas for cooking it is a must. The hood should be sized based upon the range you are using, others here have those numbers. Are you considering a basic kitchen or one of those small commercial units.
Bud
ZZZZZ likes this.
Bud9051 is online now   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
dpreznik (04-23-2017)
Old 04-23-2017, 07:54 PM   #3
Rewards Points: 181
Re: Kitchen Hoods
Thank you Bud,
We use an electric stove. But I am not sure how to answer your question. I just don't know anything about what those small commercial units are.
If we use an exhaust, will we need to clean the pipe from time to time?
Regards,
Dmitriy
Bud
Old 04-23-2017, 08:28 PM   #4
ZZZZZ's Avatar
Rewards Points: 3,298
Re: Kitchen Hoods
"Must," as in required by the building code, in most locations.
Many locations require external venting regardless of the gas vs. electric,.
As they say, "check your local listings" (building permit department).
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
The Following User Says Thank You to ZZZZZ For This Useful Post:
dpreznik (04-24-2017)
Old 04-23-2017, 08:32 PM   #5
jlhaslip's Avatar
Rewards Points: 708
Re: Kitchen Hoods
The filter units don't take the humidity out of the air, vented units do.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Old 04-23-2017, 08:57 PM   #6
Re: Kitchen Hoods
@dpreznik If it is a normal 4 burner electric stove as opposed to one of the 6 burner monsters or one that has a grill in the middle, then a standard 2 speed hood should be fine. Larger ranges can generate so much heat that is requires a larger fan to pull that air outside.
Bud
Old 04-23-2017, 10:44 PM   #7
Rewards Points: 898
Re: Kitchen Hoods
Originally Posted by dpreznik View Post
Dear experts,
Thanks,
Dmitriy
It depends more on what you plan to do with the range. If you're a big time cook vent to outside and use a 6" round. If barely know how to boil an egg, just go with the carbon filtration. I think carbon meets the current IBC.
BIG Johnson is offline   Reply With Quote
The Following User Says Thank You to BIG Johnson For This Useful Post:
Old 04-24-2017, 12:49 PM   #8
Two Knots's Avatar
Rewards Points: 4,897
Re: Kitchen Hoods
Is your stove by any chance going on an outside wall?
Our stove is on an outside wall, so we have a microwave
exhaust fan combo installed over our stove.
It vents outside straight through the wall, instead of through
the cabinet above. It works fantastically...was easy to install
as well.
Two Knots is offline   Reply With Quote
The Following User Says Thank You to Two Knots For This Useful Post:
Old 04-24-2017, 09:31 PM   #9
Rewards Points: 181
Re: Kitchen Hoods
as well.
Good idea. But no, there is another room behind the wall.
And thanks everybody who answered.
Regards,
Old 04-25-2017, 12:55 AM   #10
Rewards Points: 396
Re: Kitchen Hoods
Dear experts,
Thanks,
Dmitriy
Always try to vent out if at all possible.
My mother in law talked me out of installing hers as an outside vented. Now she regrets it and wants it changed.
Erico is offline   Reply With Quote
Tiling kitchen - Subfloor has a hump. Bigmo59 Flooring 10 09-10-2014 11:29 PM
Kitchen, Dining Room, Pantry mprice214 Electrical 23 07-14-2014 12:45 PM
Slow drainage and gurgling, overflow in kitchen sink daluu Plumbing 10 04-06-2014 11:29 PM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 10:45 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
