Kenmore Washer Pump Check - Appliances - DIY Chatroom Home Improvement Forum
Old 05-25-2019, 04:36 PM   #1
Johnny Canuck
Rewards Points: 16
Send a message via ICQ to muskox3437 Send a message via Yahoo to muskox3437
Kenmore washer pump check
My Kenmore Model 110 - 4423090, type 107 will not drain. I changed the lid switch to no avail.
I am now looking at the drain pump. It looks fine. Number is 3352492, which is identical to 3363394 apparently.
I have ordered in a new pump. It is only twenty dollars Canadian with no shipping charge.
But I cannot see any problem with the old pump. There are no clogs and it turns. I have also checked all of the hoses for clogs and have found none.
Is there some way I can verify the condition of the old pump? Could it apparently be functional but will give away under the pressure of the water and slip somehow? I only ask because I do not want to wait for two weeks for the new pump to arrive only to find it makes no difference to the operation of the washer.
The pile of dirty laundry is rising ominously
muskox3437 is offline   Reply With Quote
Old 05-25-2019, 04:39 PM   #2
retired framer
Rewards Points: 4,776
Re: Kenmore washer pump check
Did you check for power at the connections to the pump, you could have a control board problem.
Do not use flat bottom gables with scissor trusses.
Old 05-25-2019, 04:47 PM   #3
Johnny Canuck
Rewards Points: 16
This is a pretty old washing machine and has twentieth century controls on it. But I have not checked the electrical circuit out yet. Thanks for the directional tip.
Old 05-25-2019, 06:34 PM   #4
retired framer
Them it is just the controller instead of the board.
Old 06-10-2019, 06:50 PM   #5
Johnny Canuck
Rewards Points: 16
Question
I finally installed the new pump and the washer still will not drain. So I have changed the lid switch and the drain pump. That leaves the controller as the only culprit left standing---I think!
In my case the drain pump has no electrical connections and is a direct drive from the motor. It is very easy to take off and change out.
The controller is another kettle of fish. I haven't been able to figure out how to detach the controller from its mounting board yet and I don't want to break it finding out. The knob screws off easily but under that is a plastic grommet thingie that is not revealing its secrets to me.
I will see if I can get a picture uploaded.
Old 06-12-2019, 05:40 AM   #6
Rewards Points: 202
I think Mr Nealtw is saying right.
MasterPipe is offline   Reply With Quote
Old 06-12-2019, 12:21 PM   #7
Johnny Canuck
Rewards Points: 16
So . .. is it even feasible that I could repair the controller? I am trying to get a good look at the schematic and can see that I could get the back off the controller by twisting the holding tabs.
I am probably wasting my time but it would be interesting to see what is causing the problem.
Sorry about the smily. Just couldn't resist that one.
Old 06-12-2019, 09:23 PM   #8
Rewards Points: 2,592
Imo, unless you are a service tech or have the experience, skills, and testing equipment, I agree, you are wasting your time.
As you said, it would be nice to know for sure, as this is no doubt the most expensive part of the washer.
I tried googling that model number, nothing coming up for it. How old is it?
Go to sears parts direct website and ask there. See if they can help you out. Yes they are still in business. searspartsdirect.com
jmon is offline   Reply With Quote
Old 06-13-2019, 08:52 AM   #9
Rewards Points: 1,840
Often you can find a used controller on eBay as well.
huesmann is offline   Reply With Quote
pool pump electrical jackstraw Electrical 7 05-28-2019 03:47 PM
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 11:42 PM
Vibration In High Speed Spin Mode Davy49 Appliances 7 12-30-2014 10:47 AM
Craftsman Pressure Washer 580.761800 pump question SteveLake Tools 0 06-22-2011 10:51 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 08:28 PM
