Installing A Dishwasher? Is There An Outlet? - Appliances - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 4 Post By rjniles
  • 2 Post By rjniles
Old 06-01-2019, 08:26 AM   #1
Rewards Points: 1,052
Installing a dishwasher? Is there an outlet?
My wife is convinced our dishwasher is going to fail soon and wants a new one. I think she just wants a SS DW to go with our new SS refrigerator.
Anyhow.... the stores won't install one unless it is plugged in. If it is hardwired they require an electrician. I pulled the kickplate off and see a piece of romex coming off it, going across the bottom and up the back. I can't see where it goes after that. The house is 12 years old. Could it be hardwired, or is there an outlet on the back? The romex suggests hardwiring. but I've seen plugs on romex, so it doesn't prove anything.
I installed one myself 15 years ago at my old house when the store refused to do it because the garbage disposal and the DW shared a circuit. But I was 15 years younger then. Of course I had to reinstall the fridges water line myself because it leaked after the "installer" did it...
Toller is offline   Reply With Quote
Old 06-01-2019, 08:30 AM   #2
retired framer
Rewards Points: 1,540
Re: Installing a dishwasher? Is there an outlet?
That would be hard wired.
Do not use flat bottom gables with scissor trusses.
Old 06-01-2019, 10:28 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
Turn the power off, disconnect the Romex from the DW, route the Romex into the sink base cabinet and install a surface mounted box and receptacle.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 06-01-2019, 01:48 PM   #4
Turns out Lowes will do hardwires, so I am all set; though it might be best to just install an outlet and be done with it. Thanks.
Old 06-01-2019, 03:17 PM   #5
Hammered Thumb
Rewards Points: 470
There's really no need to install an outlet for a DW plug. Hardwired is the norm and quite simple. Besides, you would have to buy an approved cord kit for the DW.
3onthetree is offline   Reply With Quote
Old 06-01-2019, 03:58 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
Hard wired no longer meets code. A DW requires a disconnect at the appliance.
Sent from my Moto E (4) Plus using Tapatalk
COLDIRON and MTN REMODEL LLC like this.
Old 06-01-2019, 04:38 PM   #7
Rewards Points: 1,290
Any commercial UL cord and molded cord cap will suffice.
Anti-wingnut is offline   Reply With Quote
Old 06-01-2019, 04:43 PM   #8
Meeting current code is probably not an issue with a replacement DW if the previous one was hardwired. It is easy to presume that the hardwired unit met code at the time, so hardwiring the replacement would be allowed via grandfathering. But a unit plugged into a receptacle under the sink is so much easier to install that hardwiring is just dumb even if it is allowed.
Old 06-02-2019, 03:34 AM   #9
Hammered Thumb
Rewards Points: 470
That was my thinking, but you are correct in advising it should be at least to min code even if it were to be grandfathered. It may be more involved than just bending the romex to under the sink (passing through the cabinet wall) and if its not a currently dedicated circuit.
Old 06-02-2019, 07:15 AM   #10
Rewards Points: 2,072
Install an outlet under the sink as previously mentioned. Easier for service and troubleshooting . Easy to replace. IN an emergency you can just pull the plug. Hardwired always has limitations especially if the person who hard wired it didn't leave enough slack for service And many do . Especially delivery men who want to throw it it and get to the next one. Put the outlet in and use a cord on the dishwasher. You will be happy some year.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 06-13-2019, 03:31 PM   #11
Rewards Points: 796
With a hard wired dishwasher one only needs to have the old hard wire replaced with an appliance cord that plugs into a receptacle under the sink, same as with a garbage disposal. What is important is that there is ready access to the plug so if the appliance has a short it can be quickly unplugged before you have a fire.
Good idea to replace the drain line while you are at it with the old dishwasher removed.
Calson is offline   Reply With Quote
