Ice Maker Dumping Water Continuously - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By BayouRunner
Old 10-26-2016, 10:37 PM   #1
Rewards Points: 18
Ice maker dumping water continuously
I have a Samsung rs261mdrs side by side refrigerator and freezer. The ice maker is filling with water, then immediately dumping the water. This process repeats every 30 seconds to 1 minute leading to a puddle on the floor. The ice maker continued attempting to dump water even when the water to the fridge had been turned off. Does anyone have any ideas to try before I purchase a new ice making unit?
I have already tried resetting the ice maker and unplugging the fridge and turning off the ice maker using the button on the front of the fridge. Nothing stopped the icemaker from turning every 30 seconds. Right now I have disconnected the internal wires to the water valve and ice maker to give myself time.
Snboard976 is offline   Reply With Quote
Old 10-26-2016, 11:15 PM   #2
hkstroud's Avatar
Rewards Points: 6,390
Re: Ice maker dumping water continuously
I would replace ice maker. Timer inside of ice maker must be defective.
hkstroud is online now   Reply With Quote
Old 10-27-2016, 08:38 AM   #3
Rewards Points: 538
Hk is correct, replace the icemaker, it does not have a timer though. The way it works is every time the ice bin reaches say 11 degrees it cycles. Obviously you are no where near that temperature so I am guessing its a bad sensor in the icemaker itself or the relay in the icemaker is stuck. Either way there is no repair, as you can not buy individual parts, you will have to replace
MTN REMODEL LLC likes this.
BayouRunner is offline   Reply With Quote
Tags
ice maker , samsung
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-09-2014 12:40 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
