How High To Set The Range/oven Height? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-17-2015, 08:47 AM   #1
ZZZZZ's Avatar
Rewards Points: 1,628
How high to set the range/oven height?
I'm installing a new range/oven with a glass cooktop and I'm a bit confused about how high to set the legs.
The glass cooktop has a lip maybe 1/4" high around all 3 edges. Should the lip be flush to the countertop to the left and right of the range or should the actual cooktop be flush and the lip stands proud?
Thanks.
ZZZZZ is online now   Reply With Quote
Old 04-17-2015, 03:30 PM   #2
JUSTA MEMBER
Rewards Points: 2,420
The lip is a resemblance of a spill collector, like a levee, and is meant to contain a spill, to keep a mess confined to a smaller area.
And I see it being a slight hindrance when wanting to slide a pot on or off the range.
How does your SWMBO want it?
Unless you plan to be the main cook, I would ask SWMBO.
ED
de-nagorg is offline   Reply With Quote
Old 04-18-2015, 07:55 AM   #3
ZZZZZ's Avatar
ED
I do do most of the cooking, but SWMBO says: "You're the DIY expert, you figure it out."
With a glass cook top, I think you're not supposed to "slide" things on and off.
I'm thinking to make the top of the lip flush to the countertop to make it have more of a "built-in" look.
Old 04-18-2015, 09:10 AM   #4
JUSTA MEMBER
Sounds logical to me to have it flush.
It will function well that way, and will not catch any pot that is raised just slightly to set aside.
ED
Old 04-18-2015, 09:48 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,716
lip should be flush with counter top
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Ceiling Height for Beams 6 Inches Below Min Height skobydog Carpentry 10 04-04-2015 02:09 PM
Minimum ceiling height - Massachusetts debiasio Remodeling 2 11-27-2013 09:49 AM
Gas Fireplace Flame Height Control chh HVAC 3 09-09-2012 11:22 AM
What should be the height of wall? so roof pitch is 10 feet... vikasintl Roofing/Siding 2 07-04-2012 10:32 PM
2 Pipe Fan Coil AC vertical Cab - 1/10HP Blower Motor High Speed Problem Tyndale HVAC 5 07-10-2011 12:50 PM
