How To Handle Gap When Installing Range Hood Duct Over Tile Backsplash - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By schreibdave
Old 05-03-2019, 10:38 AM   #1
Rewards Points: 128
How to handle gap when installing range hood duct over tile backsplash
I plan to install a range hood over a tile backsplash. The backsplash runs part way up the wall. When running the range hood duct over the tile how do I handle the transition where the tile ends since the tile sits 1/4" or so off the wall?
Here's an example picture of the situation, but it's not clear how they handle the transition.
How to handle gap when installing range hood duct over tile backsplash-range-hood.jpg
slantedview is offline   Reply With Quote
Old 05-03-2019, 11:38 AM   #2
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,230
Re: How to handle gap when installing range hood duct over tile backsplash
can you draw some lines on a better picture ?
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
Old 05-03-2019, 12:23 PM   #3
Rewards Points: 128
Here's a really basic drawing that illustrates the problem from a side view. You can see the off the wall on the lower half. So if we install the duct over the tile there will be a gap on the upper half between the duct and the wall.
Old 05-03-2019, 01:23 PM   #4
retired framer
Rewards Points: 18,528
The photo you posted shows it out far enough to clear the crown, are you sure yours will be against the wall.
Perhaps some kind of trim on the wall that shows on both sides.
Do not use flat bottom gables with scissor trusses.
Old 05-03-2019, 01:33 PM   #5
Rewards Points: 128
The hood in the image I posted initially may not have been flush against the tile... it's hard to tell. Here's another install that definitely looks flush again the tile. Again, it's hard to tell how the transition between the tile and wall is handled.
How to handle gap when installing range hood duct over tile backsplash-home-design.jpg
Old 05-03-2019, 02:01 PM   #6
do you have the hood physically on hand now ??
if the gap is really going to be an issue, you could use the matching
stainless trim that Neal shows or a 1/4 round painted to match the wall.
or option B: just tile up to the lower edge of the exhaust fan.
if the tile is already there, remove it and do the patching accordingly.
Old 05-03-2019, 02:09 PM   #7
Rewards Points: 128
your kitchen = your call.
The hood is not on hand yet. The stainless trim idea might be our best bet. I'm really curious how others, such as in this picture, pull this off though. If stainless trim is used to fill the gap, I'd expect to see a line that I don't see.
Old 05-03-2019, 09:48 PM   #8
Collector of tools
Rewards Points: 120
I have a similar set up and my tile goes all the way to the ceiling
Johnny_inFL likes this.
schreibdave is offline   Reply With Quote
Old 05-04-2019, 09:07 AM   #9
Rewards Points: 2,273
I would check that the duct on the proposed hood is actually flush with the back of the hood before even worrying about it. If it's like the one in the first pic, it's not flush, so no problem. Even so, what's wrong with part of the duct being a quarter inch off the wall?
huesmann is online now   Reply With Quote
high CFM range hood install s002wjh Kitchen & Bath Remodeling 1 10-11-2016 08:22 PM
Need help installing rigid duct in attic Rav HVAC 6 07-06-2016 06:04 PM
Exhaust hood for range - Duct questions BigJimmy Kitchen & Bath Remodeling 0 09-22-2013 09:38 PM
range hood duct problem orka HVAC 0 04-26-2011 07:18 PM
installing shelving on tile backsplash indignatz Remodeling 7 11-05-2010 06:06 AM
