How To Handle This Gap Behind Cooktop? - Appliances - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 03-28-2019, 07:24 PM   #1
Rewards Points: 224
How to Handle This Gap Behind Cooktop?
We just installed a 48" gas KitchenAid cooktop, along with the required 9" high stainless steel backguard (the cooktop has a grill). However, when the cooktop is installed according to the installation instructions, there is a ~1" gap between the back of the backguard and the wall (see pics).
My first thought was to order a large backsplash made with the solid surface countertop material that matches our counters, but my understanding is granite/quartz/etc. only come in 1.25" and 3/4" thicknesses.
We are planning a tile backsplash of the entire area, but obviously tile isn't going to be 1" thick.
I found one pic on the KitchenAid site that shows some sort of plexiglass with some standoffs behind the whole area, but frankly this looks cheesy and foolish to me.
Anyone have any ideas?
How to Handle This Gap Behind Cooktop?-img_0133.jpg   How to Handle This Gap Behind Cooktop?-img_0134.jpg
nobbyv is offline   Reply With Quote
Old 03-28-2019, 07:49 PM   #2
retired framer
Rewards Points: 14,572
Re: How to Handle This Gap Behind Cooktop?
How about a granite shelf just above the range and down each side just 2 1/2"-3" deep
Tile to that,
Dave Sal, mark sr and Mystriss like this.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
nobbyv (03-28-2019)
Old 03-28-2019, 08:39 PM   #3
Rewards Points: 224
Tile to that,
Hmmm, you might be on to something: a place to place an olive oil bottle and salt and pepper shakers, say. The countertop guys actually miss-measured on a different section and ended up leaving me a spare ~6" wide, 5' long piece of the countertop material that I could even take a shot at cutting down myself (worst case I order a new piece). That's a great idea I didn't even think of. And why I come here.
Dave Sal likes this.
Old 03-28-2019, 08:52 PM   #4
retired framer
I would just put board on the wall back there to stick to. It might not be easy to match if you screw it up.
Old 03-28-2019, 09:51 PM   #5
Rewards Points: 70
You could also use some Stainless Steel and simply cover the gap and screw it to the wall, with the screws hidden behind the stove. Some manufacturers have kits just for that.
Do check the manual. Sometimes that gap is required to allow convection to keep the wall cool, so they can achieve the tight clearance with a hot device.
Cheers!
supers05 is offline   Reply With Quote
Old 03-29-2019, 09:33 AM   #6
Rewards Points: 499
Check the install manual to see if that gap is necessary and consult with the manufacturer if there is no information on it.
If you decide to add some type of cover or shelf, then keep in mind that whatever you add to it will collect grease and food particles and may need to be cleaned frequently. It would be much easier to wipe down the wall after you tile it.
I just checked my stove and I have a 2 inch gap. It is not that noticeable because the stove is colored black and the background blends in.
What I would do is to purchase a sheet of stainless steel, the width of your stove and attach that to the wall. Then tile on both sides of it if you wish.
Now that will blend in better.
rjordan393 is offline   Reply With Quote
Old 03-29-2019, 10:51 AM   #7
Rewards Points: 1,502
That gap makes no sense.. hard to believe its designed to leave a 1 gap... what is preventing it from being pushed all the way back?
How to Handle This Gap Behind Cooktop?-6a3bb366-3aad-4cc9-99f5-c90d30f6d4e4.png
ryansdiydad is offline   Reply With Quote
Old 03-29-2019, 11:01 AM   #8
Rewards Points: 316
what is the model # of the cooktop?
Tymbo is online now   Reply With Quote
Old 03-29-2019, 01:39 PM   #9
Rewards Points: 656
Need more experts to comment on this idea:
Remove that back piece.
Determine if 'wall' means combustible wall.
Prep for tile backsplash as follows:
Add 1/2 inch concrete backerboard as first layer including behind rear of cooktop.
Add 1/4 inch concrete backerboard as second layer including behind rear of cooktop.
Add typical tile next.
You may have to extend/adjust electrical boxes depth to meet new plain of tile.
diyorpay is offline   Reply With Quote
Old 03-29-2019, 01:59 PM   #10
Rewards Points: 224
Originally Posted by ryansdiydad View Post
That gap makes no sense.. hard to believe it’s designed to leave a 1” gap... what is preventing it from being pushed all the way back?
The front control panel of the cooktop is over-sized a bit to allow it to cover up the field cut made on the face frame of the cabinet it's placed in.
KGCU482VSS
Do you mean remove the back piece permanently? I'm pretty sure even with cement backerboard it would be required.
Old 03-29-2019, 03:00 PM   #11
Rewards Points: 1,435
Since you're gonna be doing back splash anyway, I'd wait to solve the problem until that's in, so you know how much of a gap you'll have. At that time, just take some 1/2" (or whatever your gap ends up as) stainless steel angle and bend it into a big U, and glue it to the back of that panel.
huesmann is offline   Reply With Quote
Old 03-29-2019, 03:18 PM   #12
retired framer
Maybe a SS trim could be made to go on the back of the range, we see SS crown around hoods at the ceiling.
Old 03-29-2019, 03:33 PM   #13
Rewards Points: 316
http://www.specsserver.com/CACHE/fraesyrbtxim.pdf
Here is the link to the installation guide.
How deep is your counter?
It looks like your stone top stops at the cooktop.(there is not a stone strip at the wall)
I would bet you can make your notches at the front of the top deeper and push the unit back to the wall.
Old 03-29-2019, 04:45 PM   #14
Rewards Points: 224
Yeah, but as I mentioned above: I had to field cut the face of the cabinet to accept the cooktop. As it stands, the controls section overlaps the cabinet face frame, hiding the less-than-perfect field cut. I *could* cut it wider and push it back, but then I'd be looking at these ragged cuts.
Nealtw likes this.
Old 03-29-2019, 11:45 PM   #15
Contractor/Engineer
Rewards Points: 1,084
Looks like the countertop or base cab has to be notched back. Kind of an easy fix with a diamond blade on a right angle grinder and/or a multi-tool.
Some countertops are 24", some 25.5", etc. appliance and countertop installers with experience know what to look for in most cases.
The solution to add a shelf is nice - or put on a full 3/4" backsplash of matching granite.
I'm actually thinking someone may not have read all the notes on the installation instructions.
Domo is offline   Reply With Quote
Replacing shower handle and valve 012abc Plumbing 19 06-30-2018 08:30 AM
Delta Monitior 14 Series Shower Handle falling off tjonzun Plumbing 1 05-05-2018 04:56 PM
Cannot figure out how to remove door handle ercussio Windows and Doors 6 02-11-2013 09:52 PM
Screen/Storm Door Handle Height Steven Z. General DIY Discussions 2 11-22-2009 04:38 PM
Storm Door Handle Installation jogan General DIY Discussions 3 06-09-2009 09:57 PM
